Old 08-08-2013, 09:03 PM   #46
Yea i will use an FB axle in the rear and that will match the front. And wicked flares Are a must!
Right now its mounted using stock fc mounts. Might have to consider seatig position with how its turning out. The oil filter would be in your shin stock wise
Old 08-08-2013, 09:12 PM   #47
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
The FB axle has quite a bit narrower track than the FC front. It could be compensated for with low or negative offset wheels though. The GSL-SE axles will also push the wheel out a little further than other FBs. Only way to tell for sure is to try it.
That does sound a little far back. How did you get it in there? Remove the firewall?
Old 08-08-2013, 09:32 PM   #48
Ive been using gslse stuff. Gets about an extra 20mm.
Yea trimming was required
Old 08-12-2013, 06:50 PM   #49
Car is now in california. Next step will include coilovers and rx7 axle mit four link
Old 08-13-2013, 10:11 AM   #50
RXTASY
idahorotary.com
RXTASY's Avatar
RXTASY is on a distinguished road
So you in Cali now?
Come visit us if you are ever in the area.
87 TII-E85-600+ RWHP and climbing
Life starts at 2 bar!
Come visit my forum! idahorotary.com
http://idahorotary.com/smf/index.php
RXTASY is offline   Reply With Quote
Old 08-13-2013, 11:24 AM   #51
Fidelity101
Reliable Source
Fidelity101's Avatar
Those 15s do look huge on it lol.
My Rx-7 Vids
Old 08-13-2013, 12:48 PM   #52
Originally Posted by RXTASY View Post
So you in Cali now?
Well hanging out for a couple weeks then officially In CA
Yea needs eiter 14s or a smaller tire or both
Old 08-13-2013, 01:11 PM   #53
GySgtFrank
GySgtFrank's Avatar
Just properly sized wheel openings on the custom widebody you're going to have to build. 'cuz you need moar tire.
Old 08-13-2013, 07:53 PM   #54
indeed. I am thinking about taking a class on how to use the "english wheel" and build my own sheel metal flares.
Old 08-13-2013, 08:36 PM   #55
GySgtFrank
GySgtFrank's Avatar
Something like this?
Just have to setup the wheel arches to follow the chosen size 15" tire that you'll be using.
Old 08-13-2013, 08:52 PM   #56
chibikougan
chibikougan's Avatar
Also motorcycle fenders cut in half?
Old 08-13-2013, 10:30 PM   #57
Yup a lot like that Frank. Just not sure on on wide to go. Need to find the wwheels i want to use
Old 08-13-2013, 11:00 PM   #58
chibikougan
These?
This can also be done by cutting a radius in the stock flare.
Pull open gap to desired flare. Fill in the gap...
Old 08-13-2013, 11:06 PM   #59
Eh more buldge on the top though i think. I will have to find a picture
Old 08-13-2013, 11:10 PM   #60
chibikougan
Something round? This is for a 16in wheel they also have a full round wide fender.
