Old 10-10-2012, 09:17 AM   #1
Alex Rodriguez
Alex Rodriguez is on a distinguished road
Hello everyone
My name is Alex Rodriguez same one from rx7club I drive
93 FD- track car/show car /weekend driver
86 FC- daily driver
87 FC- time attack build
08 m3-daily to daily driver lol
Alex Rodriguez is offline   Reply With Quote
Old 10-10-2012, 09:35 AM   #2
Alex Rodriguez
My FD3s mod list is as follows
Suspension-----
Stance GR+3w/External reservoirs
Suspension Techniques front sway bar
Racing Beat front lower swaybar mount brace
Engine
Large streetport ,ALS seals, Atkins solid corners, full Mazda OEM spring and seals kit, Rotary Aviation coolant seals,orings and oil control seals.
Silicone vacuum hose conversion
OMP delete kit including drive gear for less strain in front assembly
M2 Performance lightweight aluminum flywheel
B and M short throw shifter
ACT HD PP +6 PUC
New pilot bearing and seal
Turbo-----
Garrett TO4z
gt35r compressor wheel
.70a/r compressor
4” diameter compressor inlet
.96 hotside
polished compressor
HKS 304 stainless exhaust manifold
Tial 40mm wastegate 1.0 bar spring
HKS blowoff valve
Custom engine compartment turbo heat shields
Custom intercooler system made By GARRETT
12 x 18 x 3” (H/W/T) Garrett core w/ custom fin sets
Slant mounted (for max size, space, and performance)
Custom cold-side air ducting using original factory air supply duct
Custom sheetmetal end tanks
2.5” intercooler plumbing
12” Spal draw-through fan
Custom cold air intake system
Sealed aluminum airbox w/ DEI reflecta gold
Nose/under-car air source
K&N cone filter (6” max diameter)
4” duct from air box to compressor inlet
Custom oil cooler system
Dual 19-row Setrab oil coolers
Mocal oil thermostat
-10AN SS braided lines and fittings
Parallel plumbing configuration (for max effectiveness and min pressure drop)
Mazdaspeed oil cap
Rotary13b1 brake cap
Cooling system-------
MazdaComp aluminum race radiator
185º thermostat
FC thermoswitch (changes fan switching temp from 226 to 203F)
Auxiliary electric cooling pump (to prevent hot shutdown heat soak)
Air separation tank (AST) removed
Cooling fan relays rewired to eliminate low speed operation
4 vent carbon fiber Knightsports extractor hood (to reduce underhood temps)
Greddy water pump underdrive pulley (to prevent high speed cavitation)
AC system removed
DEI reflect -a-gold on intake box, radiator,and lim uim
Custom exhaust----
3” v-band downpipe (w/ shielded flex section open dump pipe)
3"to 4" stepper
TRUST 4" mid pipe Rare!!!
TRUST 4" MID PIPE BACK Super mega exhaust
TRUST V-band-clamp connections
MANAGEMENT-----
APEXI power FC
APEXI commander
LS2X YUKON coils with individual built in igniters
Fuel
Cj motorsports primary rail
Rx7store secondary rail with fuel temp bung
Bosch 1680 cc secondaries
Injector dynamic 1000cc primaries
Aeromotive FPR
Summit Racing -8AN 40 micron filter
Summit racing fuel gauge
JEGs y-block
Russell Y-block
BOSCH 044 in tanks
-8 FEED nylon braid lines with all hardended fittings
Brakes-----
Brembo front rotors
Goodridge SS braided lines
Motul 600 fluid
Hawk Blue pads (track only)
ABS- Delet kit - earl/xrp fittings in braided lines
SSBC proportioning valve
Gauges
Prosport boost gauge
Prosport oil pressure gauge
Prosport water temp gauge
Prosport 60mm triple center pod
INNOVATE Timer wideband AFR w/digital display and datalog to TEC3
INNOVATE LC-1WIDEBAND LAMBDA
HKS turbo Timer
Afc hand held
Other-----
Magnecor 8.5mm plug wires with MSD ls boot ends
Bosch battery relocated behind passenger in storage bin
Custom hidden trailer hitch (used to tow race tires to track)
Greddy alternator pulley
Greddy underdrive pulley
Greddy water pump pulley
Custom aluminum catch can
Greddy aluminum intake elbow
INTERIOR
RECARO Spirit R seats
recaro reclining seat rails
AUTOPOWER 6 point cage
MOMO veloce 20yr old vintage race wheel with RARE red Horn
miata wheel hub
NRG quick release
FULL BLACK INTERIOR CONVERSION
broadway mirror
glass sunroof
3 over ride switches for external water pump, radiator fan, intercooler fan
Pioneer avic 1double din
Kicker DS 6x8 mids
Kicker DS Tweeters
Kicker DS crossover,
Alpine small 1000watt amp
JL audio w6 10" subwoofer
Custom Fiberglass enclosure built by me
JDM arm rest
TRUST shift knob
EXTERIOR---
VERTEX bumper
VERTEX side skirts
RE Amemiya rear CARBON track Diffuser
RE Amemiya gt3 wing
Knight Sports vent hood
Uras turn signals
Converted 99 tails
4 prong LED bulbs
Glass sunroof
RE Amemiya sleek lights,evo r 90 mm HIDs
WHEELS-
Work Equip
18x10 +22 Front 18x11 +22 Rear
TOYO R888 race tires
285-30-18
255-35-18
Project KIcs r22 lug nuts
Old 10-10-2012, 09:36 AM   #3
Alex Rodriguez
Old 10-10-2012, 11:55 PM   #4
Welcome buddy! Glad to see you made it over here. It's Eric by the way. I didn't realize you had two FCs also.
Old 10-11-2012, 11:32 AM   #5
Alex Rodriguez
Yooooo lol yup actually 4
Old 10-11-2012, 05:11 PM   #6
Slammedred7
Slammedred7 is on a distinguished road
Hi.
13B-RE Full Bridged....and a few other mods
Slammedred7 is offline   Reply With Quote
Old 10-14-2012, 11:51 PM   #7
4 FCs or 4 RX-7s total? lol
Old 10-26-2013, 09:56 PM   #8
hozzmanrx7
7Club Refugee
hozzmanrx7's Avatar
hozzmanrx7 is on a distinguished road
Hi
Does the Avitar look familiar?
"he's a tool that moved from being an abusive moderator to a troll that acts like a tool to get his attention now."
John (Jon) Michael Borry = RX7roller02 = skydivr7673 And that's the truth. http://rotarycarclub.com/rotary_foru...t=17659&page=7
hozzmanrx7 is offline   Reply With Quote
Old 10-26-2013, 10:22 PM   #9
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Welcome Alex. Dang, have you got any mods you haven't done yet?
My one 1stGen is enough to drive me slightly batty, but 4 RX-7s?
Old 10-27-2013, 11:22 AM   #10
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
sup Alex.
http://rotaryevolution.net
Old 10-27-2013, 12:13 PM   #11
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I think you guys are about a year late to the party
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 10-27-2013, 01:53 PM   #12
GySgtFrank
GySgtFrank's Avatar
Party pooper. Now I feels stoopid for not checking the thread date. The deleted pictures should have tipped me off. Oh well, welcome anyway Alex, wherever you are.
Old 10-27-2013, 03:46 PM   #13
ZGN
Administrator
ZGN's Avatar
I took a great photo of him on the track at 7Stock last year.
Kevin
Old 10-27-2013, 10:37 PM   #14
silverfdturbo6port
500hp club
silverfdturbo6port's Avatar
silverfdturbo6port is on a distinguished road
Nice looking car
500hp AEM EMS RotaryAutomotive street ported Aviation sealed 13b-rew
20B 20BEEST FD
23A 4 rotor Long gone
72 rx3 drag machine
silverfdturbo6port is offline   Reply With Quote
Old 10-28-2013, 11:12 AM   #15
Alex Rodriguez
Woot wooot
