Old 11-11-2013, 03:55 PM   #1
mystery
mystery is on a distinguished road
no power?
Finally got my 85 running and went out to crank and tune the carb last week and when I went to crank it battery started smoking on the positive side and ended up taking out my battery... so I put a new one in it and now I have no power at all... checked my fuse box under the dash all are good and I found my manuel and its mentioning something about fusable links so I checked those and I dont see burning or anything abnormal for a wire connection 30+ years old. Any ideas??
mystery is offline   Reply With Quote
Old 11-11-2013, 04:30 PM   #2
JL1RX7
Check/replace your terminals. It might have smoked checked them out. Check all fuses and go from there.
Old 11-11-2013, 04:34 PM   #3
mystery
Checked all that. What was smoking was the cable that was melting into another wire. Something shorted cause when I tested my old battery it had 35% on it which should have been enough to move the dash guages...
Old 11-15-2013, 11:38 AM   #4
mystery
So I got to take a look at it today finally and came across a frayed wire goin into the starter. Got it replaced and theres still no juice. Dash wont even lightup...im puzzled.. [img] http://s1348.photobucket.com/user/my...bile%20Uploads [img]
Old 11-15-2013, 06:16 PM   #5
mystery
Sorry about the tripple post but after talking to atkins rotary and making a stop by my local dealership ive comeup with a possible cause and only place I can find it is in Pennsylvania part number is FA56-66-760 and its called the main fuse case is what the dealership called it located on the driverstrut tower with a direct line into the battery. And it cause nothing to work no power at all from what atkins told me. So after I get it ill update to let everyone kno if its my issue.
Old 11-19-2013, 04:36 PM   #6
mystery
Problem was fixed by replacing the fuse case.
Old 11-19-2013, 04:42 PM   #7
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Glad to hear you got it figured out.
