Old 06-04-2008, 05:42 PM   #1
P71
P71's Avatar
How to put FC seats in an SA/FB
Step 1: Get FC seats (you don't even need the tracks).
Step 2: Take out old seats, remove tracks.
Step 3: Install SA/FB tracks on FC seats.
Step 4: Re-install.
Step 5: Profit!
This is only for manual tracks, I don't know if power tracks will work.
I've actually had the FC seats in my FB for 2 months now, but one of the 3 bolts holding the driver's seat in came loose, so I took it out to inspect (using FC tracks the passenger seat bolts right in and the driver only works on 3/4, the front inside bolt doesn't line up). I still have my original seats, so a little curiosity netted me the realization that the lower and lighter FB tracks bolt right onto the FC seats. Problem solved!
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
Old 06-04-2008, 10:54 PM   #2
Eatmyclutch
business as usual
Eatmyclutch's Avatar
Eatmyclutch is an unknown quantity at this point
lol I need to bolt on my passenger seat. I need bolts and brackets, maybe even replace the seat.
Bitch
Eatmyclutch is offline   Reply With Quote
Old 06-05-2008, 02:18 PM   #3
I have T2 seats in my FB.
Some extra things to note.
When using FB sliders on the FC seats, the FB sliders are only single lock, not dual which is why some people prefer the FC slider over FB. Personally, I didn't care. I wanted the lighter weight and lower.
If you use the FC slider on an FB seat on the driver side, you'll need to notch the fourth hole (make the circle hole a rectangle). This way it'll fit and you have 4/4 instead of 3/4.
Using FB sliders on the passenger side with FC seat, the FB slider doesnt bolt EXACTLY up. There is one of the threaded holes that doesnt line up.. luckily though Mazda had another hole about an inch further up the rack that lines up perfectly. You just need to get a bolt/lock washer/nut assembly since its not threaded.
I'm pretty sure I have thread here with pics I'll see if I can dig it up...
Old 06-05-2008, 03:10 PM   #4
P71
P71's Avatar
I left the FC sliders on the passenger seat since it bolted right in 4/4.
Michael Pinto
Vote for the ROTM!
Old 06-05-2008, 08:28 PM   #5
Perhaps a difference w/ S4 T2 seats vs what you used?
Old 06-05-2008, 08:50 PM   #6
P71
P71's Avatar
I don't know what year/model/trim my FC seats came from. They're blue cloth with thick side bolsters and high backs. Look an awful lot like the seats in my 86 GXL if I'm remembering correctly though.
Michael Pinto
Vote for the ROTM!
Old 06-05-2008, 11:18 PM   #7
Eatmyclutch
business as usual
So can I just use the FC seats and brackets into a 1st gen?
Bitch
Old 06-06-2008, 12:01 AM   #8
P71
P71's Avatar
No. You have 3 options.
1: Use the FC tracks an re-drill the driver's front inboard track to match the FB bolt hole.
2: Use the FB tracks on the FC seats with a bolt/washer/locknut holding in the off bolt to a pre-drilled hole on the passenger seat track.
Or 3: (What I did) Use the FB tracks on the driver's seat and the FC tracks on the passenger seat, then it all bolts right in.
Michael Pinto
Vote for the ROTM!
Old 06-06-2008, 03:17 PM   #9
^ Ah I see - theres our difference. I used my stock FB sliders on both sides. Was no trouble at all... I didnt find the thread here so I'll repost the pics in here.. ya know, keep it in the family.
Old 06-10-2008, 08:40 AM   #10
Kentetsu
Kentetsu's Avatar
Anyone ever do a writeup on mounting 3rd gen seats in a 1st gen? I've got a set ready to go in.
Old 07-03-2008, 10:22 AM   #11
does any one have an exact idea of how much lower it is? im 6' and the FB seats don't cut it for me.
Old 07-03-2008, 05:58 PM   #12
P71
P71's Avatar
I'm 5'11" or 6'0" depending on who you believe, and I can now sit in the FB (which has a sunroof and a sagging headliner) WITH my full-face Snell-rated race helmet on, and not touch the headliner (with the helmet, at all). I couldn't do that with the FB seats.
Michael Pinto
Vote for the ROTM!
Old 07-11-2008, 07:10 PM   #13
djjjr42
djjjr42's Avatar
djjjr42 is on a distinguished road
While we're at it let's get one for the RX-8 seats. I've got 2 waiting to go in.
'83 GS, Misty Blue, 45k miles: RB SP Exhaust, Springs, & Front Sway, Weber DCOE, etc.
'83 S, Black, 127k miles: Current Project, Stock (for now)
djjjr42 is offline   Reply With Quote
Old 07-11-2008, 08:57 PM   #14
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
impulsive-RX7 is offline   Reply With Quote
Old 07-21-2008, 09:06 AM   #15
RX-7 Chris
RX-7 Chris's Avatar
I just did this and I think it is about 1" lower than the FB seats.
