Old 01-22-2015, 06:15 AM   #346
sa22c
sa22c is on a distinguished road
I will be mighty tempted on a 250mJ CDI COP setup in the future!
I'm interested in a review of the Ohlin's coilovers. After a few years of ownership are you still happy wit them? Is there height adjustment range adequate for a true street / track car?
Have you driven anything with better handling and comfort in the suspension department in the time since you bought them?
sa22c is offline   Reply With Quote
Old 01-22-2015, 06:18 AM   #347
RICE RACING
Don Mega
RICE RACING's Avatar
While I have not owned everything myself I have had the opportunity to drive LOTS of cars fitted with all the big brands inc race stuff made here in Australia and my own opinion is nothing is better than the Ohlins, my car is a street car #1 and used as such, the suspension is perfect for that and good enough on track too.
Spring rate and damper settings are spot on, very comfortable with zero bottoming at full pace, cant ask for anything more.
I like them anyway.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-22-2015, 07:23 AM   #348
sa22c
I like them anyway.
When you say Race stuff made here in Australia are you talking about MCA race series suspension? The high end ohlins sound awesome. Can you give an indication of height in mm to front and rear guard and roughly where you are in terms of bottom perch adjustment? Do yours have helper springs front and rear?
Old 01-22-2015, 07:57 AM   #349
RICE RACING
Don Mega
Proflex mainly
ride height is legal 100mm of ground at lowest point is how I set it up.
Car can be jacked higher or much lower, just depends how much pre load on springs, all 4 have helper.
When I was in NSW I did a blue slip inspection with my Ohlins in and set to factory ride height spec for the SP.
Then changed it to minimum legal height.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-29-2015, 08:21 AM   #350
RICE RACING
Don Mega
Old 01-31-2015, 10:57 PM   #351
RICE RACING
Don Mega
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-21-2015, 08:25 PM   #352
RICE RACING
Don Mega
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-21-2015, 09:33 PM   #353
V8eter
V8eter's Avatar
V8eter is on a distinguished road
Very nice peter, presentation of your product is second to none, keep the dream alive
V8eter is offline   Reply With Quote
Old 02-24-2015, 08:03 AM   #354
RICE RACING
Don Mega
Thanks, one thing is for sure I will never use any other inferior apex seal nor will I rest till all of the shonks are driven out of this industry, people producing and promoting total garbage simply brings down rotaries to a laughing stock! no wonder when you see shit > http://rotarycarclub.com/rotary_foru...t=17258&page=5 trajic! and morons still buy that crap cause its in a drug car LOL...........
Exploding ceramics to raping galling banana seals.... they are all fucked! that is why I made my own!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-14-2015, 01:25 PM   #355
RICE RACING
Don Mega
Some new porting to test out.....
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-15-2015, 02:33 PM   #356
Topgear
Topgear is on a distinguished road
Great work peter I'm on version one of my intake ports will see how they are in a few weeks yours look lush
95 FD3S Type RB Project BorgBoost 550BHP
93 FD3S Project 26B
1200+bhp rolling road dyno
+44161 4948343
www.tgstuning.co.uk
https://instagram.com/craigtgs/
Car looks jizzfactor3000 good!
Topgear is offline   Reply With Quote
Old 03-15-2015, 03:09 PM   #357
RICE RACING
Don Mega
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-16-2015, 12:26 AM   #358
Slides
Slides is on a distinguished road
Obviously you are increasing the flow area significantly when you move the opening edge out and lift the closing edge of the port, have you ever keyed and back filled the port bowl with resin or even welded/brazed to try to maintain the runner area a bit more consistent right up to the rotor face?
Slides is offline   Reply With Quote
Old 03-16-2015, 01:16 AM   #359
RICE RACING
Don Mega
I am not sure how much benefit it would be, if you look at these angles at largest rotor opening, it still has to force its way through? not sure how much gain would happen with it.
I did mess around with that exact thing you are talking about on some 2 stroke racing engines I was preparing and it did work on those well.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-20-2015, 04:32 AM   #360
RICE RACING
Don Mega
Some more angles of the Don
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
