Closed Thread
Old 10-26-2015, 01:48 PM   #166
almoststockfc
almoststockfc's Avatar
Pushing hard to have this one at DGRR. My track record for getting a car there is less than admirable though.
lol ditto
-75 RE_W_PU -
almoststockfc is offline
Old 10-26-2015, 02:05 PM   #167
Originally Posted by almoststockfc View Post
lol ditto
ditto......
djmtsu is offline
Old 10-26-2015, 02:39 PM   #168
FC Zach
FC Zach's Avatar
ditto......
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
FC Zach is offline
Old 10-26-2015, 05:05 PM   #169
Done with work, so back to the car. Ordered exhaust parts from Racing Beat and am in search of perforated SS tubing to build a couple of mufflers. Also in need of an S4 wiring harness which I have not been able to find as of yet.
Which S4 harness you need? High or low imp injector harness/clips? I might have one laying around in the shop but I can't remember which it is.. I'll have to take a look lol...
WE3RX7 is offline
Old 10-26-2015, 05:09 PM   #170
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Shit!, I don't remember. I had it figured out once too, but old timers disease has struck again. The engine is from a 1987 GXL.
edit: spent the day putting together a cardboard template so I can get a radiator ordered from Ron Davis Radiators. This trying to fit 10lbs of potatoes in a 5lb sack is getting a little tedious.
Here are some pictures of my primary injectors and one of my better injector clips. Somebody should be able to identify them without having to go digging again.
primary injectors by Kevin Frank, on Flickr
injector clip 2 by Kevin Frank, on Flickr
injector clip 1 by Kevin Frank, on Flickr
GySgtFrank is offline
Old 10-29-2015, 12:30 PM   #171
GySgtFrank
GySgtFrank's Avatar
OK. Since nobody can identify whether my injectors are high or low impedence by sight, I will need to go digging to find out again.
I wish I would write these things down.
So, my exhaust parts showed up today.
exhaust parts by Kevin Frank, on Flickr
2 - 48" long straight pieces of 2"OD .120 wall tubing (The extra shorter piece is what I have left from my earlier adventures)
3 - 48" long pieces of perforated 409 SS tube (The ones in the cardboard tubes. I probably got more than I am going to need for this project, but they weren't that expensive.)
5 - 3" radius 180 degree mandrel bends (same tube as the straight pieces)
2 - 4" radius 180 degree mandrel bends (again, same tube as the straight pieces)
4 - SS Racing beat road race flanges
4 - Mild steel Racing beat road race flanges
5 - Exhaust gaskets for above flanges
The only pieces that I should need to complete the exhaust system now should be SS wool for muffler packing, more hangers, aluminum sheet for heat shielding, and SS sheet to make the muffler cases. I am not too sure that I want to total up what the exhaust system for this thing is going to end up costing. :shudders:
Old 10-29-2015, 01:18 PM   #172
RXtacy
RXtacy's Avatar
Looking forward to seeing how this comes out.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
RXtacy is offline
Old 10-29-2015, 02:45 PM   #173
Your *fuel injectors* are low-impedence.
I dunno about those clips though...
The offset key is a late-87 or 1988 model harness.
I'm not an NA guy, but the offset key on a turbo FC means high-impedence.
Finding those rectangle, off-set key fuel injectors might not be easy...
If not, just clip them and use "Bosch" plugs to fit those low-impedence fuel injectors and just add a ballast resistor in the circuit.
RETed is offline
Old 10-29-2015, 02:58 PM   #174
GySgtFrank
GySgtFrank's Avatar
Thanks Mike and Ted. I figured somebody would have the answer. It is going to be a while until I get to the injectors and wiring, now that I have the money for parts. I need to get the exhaust and cooling system done before I can move on to pulling the engine again. It needs to come back out so I can get the finish welding done and wire it up.
Old 10-29-2015, 02:58 PM   #175
Soooooooo.......you don't know how to work a multimeter?
That's OK, because you can weld
djmtsu is offline
Old 10-29-2015, 03:01 PM   #176
GySgtFrank
GySgtFrank's Avatar
Multimeter assumes that you have functional wiring which I seem to be somewhat short of, besides I'm a lazy old fart.
Old 10-29-2015, 03:07 PM   #177
RXtacy
RXtacy's Avatar
You would be taking the impedance across the injector, so "functional" wiring would be of no consequence.
I would assume low is in the 2-3 Ohm range w/ high being ~12.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
RXtacy is offline
Old 10-29-2015, 03:57 PM   #178
GySgtFrank
GySgtFrank's Avatar
You are determined to get me side tracked aren't you?
My neighbor/landlord used my multimeter to test a 200amp line going to the house. The leads didn't survive and the meter seems to have lost it's mind. I guess I really need to buy a good quality multimeter again one of these days. Any suggestions on a good one? I've had enough of the cheapies that work a time or two and then you have to throw them away.
Right now I'm trying to get my pipe bender stand fixed. Welding the crappy casters that I replaced on my wheel dollies to the stand so I can move the heavy bastage. I need it out where I can work on my perforated tubing.
Old 10-29-2015, 04:51 PM   #179
JL1RX7
Gunny - Fluke if you have a big budget. They are worth it. But hot damn do they cost an arm and a kidney. The one I use for work lists around 800. You should be able to find a decent one in the 150 to 200 range.
JL1RX7 is offline
Old 10-29-2015, 04:58 PM   #180
hades
Good luck old man.
This is going to tear
hades is offline
Closed Thread
