Old 05-02-2016, 10:47 PM   #46
FC Zach
FC Zach's Avatar
Originally Posted by project86 View Post
I guess you're still running all factory mounts then Zach?
I am, definitely all new components including the crossmember but as far as whether or no I got the stiffer version, I cant remember.
On another note.. i just finished the install of my short shifter. Yummy
although its much stiffer. I guess i just need to drive it an break it in some. Or maybe add some more gear oil to the shifter hole? any suggestions on that?
Yes, you should have added oil to the shifter housing.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 05-03-2016, 07:04 AM   #47
project86
Can't.Make.Up.My.Mind.
project86's Avatar
ok cool. Yeah who knows... i may end up right there with you. We'll see. My guess is that since I'm not driving the car every day, even if it does wind up vibing more than i remember I won't be bothered.
Shoot.. it looked like it had enough in it. Looks like I'm making a trip to buy gear oil today then. Luckily its not hard to take apart all of that.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 05-03-2016, 07:42 AM   #48
FC Zach
FC Zach's Avatar
It doesn't need to be overflowing, there just needs to be some in there. . I assumed that with the cars age it would have been dry
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 05-03-2016, 08:01 AM   #49
project86
project86's Avatar
agreed. According to mazdatrix it wasn't quite full enough but there was still a decent amount in there it seemed. The stock shifter didnt really feel notchy at all but it was like a floppy sausage. Now the new shifter is obviously nice and tight but also pretty notchy. Do you think adding more fluid will help that?
'90 GTUs
'10 Toyota Prius
Old 05-03-2016, 08:27 AM   #50
FC Zach
FC Zach's Avatar
May just be the feel of them, I have the same shifter in mine. . you have new upper and lower bushings matched with decreased leverage so it is definitely gonna feel different than what most 2nd gen owners are used to which is a floppy sausage lol
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 05-03-2016, 12:27 PM   #51
Actually, Mazda does not fill the shifter extension housing with any fluid from the factory...
So, all stock cars which have never had the transmission serviced should be dry.
IIRC, even the FSM does not instruct you to do so?
Most of us do - it doesn't hurt anything.
One negative is that if you DON'T have good shift boot covers (all THREE of them! - well, at least the most expensive, inner one with the metal flange), it's going to make a mess!
Old 05-03-2016, 12:46 PM   #52
project86
project86's Avatar
Good to know Ted! Luckily before I ordered the short shifter (which comes with the inner boot) I checked the condition of the other boots as well. They were gone. So I now have all new boots down there
'90 GTUs
'10 Toyota Prius
Old 05-03-2016, 02:38 PM   #53
FC Zach
FC Zach's Avatar
Very interesting. . . I thought I had read somewhere (don't remember where though) that it needs oil poured in it. Good to know, thanks.
Just checked my old Haynes manual I use (I knew I wasn't making this up lol) and found that instruction. .
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 05-03-2016, 03:09 PM   #54
[img]https://farm8.staticflickr.com/7452/26525876970_3b57e43360_k.jpg[img]
Haynes?
What's that?
Old 05-03-2016, 06:31 PM   #55
I'm not sure if impressed or embarrassed that I have a somewhat impressed that I have parts of the fsm of all three gens memorized
Old 05-03-2016, 07:20 PM   #56
project86
project86's Avatar
Im impressed for you?
'90 GTUs
'10 Toyota Prius
Old 05-04-2016, 08:37 AM   #57
project86
project86's Avatar
So i just got to thinking... I'm making a parts list so i can keep track of the stuff i need/want. Since the GTUs has the turbo suspension components wouldn't that mean that id need to buy Coilovers and such for the turbo car? Or does are the mounting points the same for turbo and non turbo cars?
'90 GTUs
'10 Toyota Prius
Old 05-04-2016, 10:08 AM   #58
Same.
Old 05-04-2016, 12:02 PM   #59
project86
project86's Avatar
Same.
Sweet. Thank. You. Brian.
'90 GTUs
'10 Toyota Prius
Old 05-04-2016, 12:37 PM   #60
Yep, as TTT said, it's the same...
In fact, the base models had the "special" suspension and brakes.
GXL is the "loaded" model, and the turbo (i.e. Turbo II) is a GXL + turbo engine.
The 1998 "GTU" + 1989 / 1990 "GTUs" are just GXL models minus all the heavy (i.e. powered) shit and some special features (i.e. no sunroof, but amazingly there are some that did come with sunroof).
The 1986(?) and 1987 has a "Sport" model available, and this was a precursor to the 1988 "GTU."
The brakes are standard across the board with the exception of the base models; this is for the 4-pot fronts with vented disc and 2-pot rears with vented disc.
This big brake or heavy-duty brake package were on all GXL, turbo, and convertible models + the abovementioned 1988 "GTU" and 1989 / 1990 "GTUs" models.
Brakes on base models - 1986 / 1987 "base" + 1988 "SE" - had the 2-pot(?) front with vented disc and single-pot rear with NON-vented disc; these were obvious due to the 4-lug wheel lug pattern.
In 1989 - 1991 base models, all FC's were 5-lug wheel lug pattern, but the base models had different brake calipers and discs.
(Forgot some of the specifics here...)
Let's see how long before the corrections come flying in...
