Old 08-07-2017, 10:41 AM   #1
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Oil Cooler
Since im ALWAYS BAW I think a lot about my car. Today, I'm thinking about oil coolers. I've had this idea for a while.... but first:
What are some good aftermarket OC set ups? I like idea of a dual set up but most of the kits I see are for the FD platform. I imagine I could modify anything to fit but I wondered if anyone here is running a slick set up I could see.
Now my idea.... I'm non turbo. I was thinking that it would be SWEEEEEEEEEET to VMount the radiator and oil cooler(s). Has anyone ever done that?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 08-07-2017, 10:43 AM   #2
You don't need to upgrade yours. In fact, FC oil coolers ARE an upgrade for many, many other cars!!!!
Old 08-07-2017, 10:47 AM   #3
project86
project86's Avatar
Right after I posted this I went over to Mazdatrix and they said essentially the same thing.
Is there any advantage in moving to a dual set up like the FDs have?
'90 GTUs
'10 Toyota Prius
Old 08-07-2017, 11:01 AM   #4
Pete_89T2
Pete_89T2's Avatar
Nope, just more things to break and/or leak. If you consider that sort of thing an upgrade.
Old 08-07-2017, 11:03 AM   #5
project86
project86's Avatar
Hahaha.. ok fair enough. I'll just get new lines then.
Now what about the VMount idea?
'90 GTUs
'10 Toyota Prius
Old 08-07-2017, 11:05 AM   #6
Johnny_K
Johnny_K is on a distinguished road
V mount Radiator and oil cooler(s) on a NA FC? Why?
If it's been done, I'm sure ppl have talked about it on rx7club.
Most of the FD guys run Setrab, Mocal coolers and thermostat.
Johnny_K is offline   Reply With Quote
Old 08-07-2017, 11:11 AM   #7
Johnny_K
No. Some of the FDs run two oil because 1 is too small for track use.
I'm don't follow FC builds but i have seen anyone Vmount on a NA. People probably don't do this because the stock setup works well.
Old 08-07-2017, 11:12 AM   #8
project86
project86's Avatar
In my mind for the same reason you would Vmount a radiator and intercooler.
'90 GTUs
'10 Toyota Prius
Old 08-07-2017, 11:41 AM   #9
Not necessary. It gets great airflow as it is, and has short lines, so it is simple.
FYI- the oil cooler from my Cosmo is considered an upgrade for any rotary, since they are like 8 core!!
Old 08-07-2017, 11:43 AM   #10
project86
project86's Avatar
Do you have an extra????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ????????????????
'90 GTUs
'10 Toyota Prius
Old 08-07-2017, 11:46 AM   #11
Johnny_K
On a FD if you put an intercooler in front of the radiator it blocks airflow to the radiator therefore it doesn't cool the intercooler as good as it should. That's why people go v mount.
Old 08-07-2017, 12:29 PM   #12
Sure thing. Comes with a semi-roller Cosmo. $3000. Free delivery.
Old 08-07-2017, 12:39 PM   #13
project86
project86's Avatar
To quote you... "No love for locals?"
'90 GTUs
'10 Toyota Prius
Old 08-07-2017, 12:42 PM   #14
Uh, I said free delivery?
Geez.
Old 08-08-2017, 02:22 AM   #15
FC Zach
FC Zach's Avatar
What are some good aftermarket OC set ups? I like idea of a dual set up. . . I imagine I could modify anything to fit but I wondered if anyone here is running a slick set up I could see.
I'm glad it's already been mentioned that you'd be downgrading. . even if you did a twin set-up (aside from the extra failure points and places to leak, like Pete said), the two combined still wouldn't suffice when compared to the OE part. Especially without going the extra mile to build duct work to each to even have a fighting chance.
For what it's worth, (IIRC) my oil temp is typically ten or more degrees cooler than engine temp when driving.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
