Old 09-12-2017, 07:32 PM   #346
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Looks like that 'tire tech' is installing the lug nuts after the car is down. Brilliant!
He was just torquing them.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 09-12-2017, 11:29 PM   #347
FC Zach
FC Zach's Avatar
Brilliant!
I was more or less saying I didn't see the issue, in a smart alec kind of way But I get your point, especially if the wheels are aftermarket without centering rings and especially with flanged seat lug nuts.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 09-13-2017, 10:31 AM   #348
project86
project86's Avatar
Who's alec? He doesn't sound very smart...
'90 GTUs
'10 Toyota Prius
Old 09-15-2017, 07:35 AM   #349
Johnny_K
Johnny_K is on a distinguished road
First step, pull back the boot on the slave cylinder and check for leakage. Second step, pull the trans!
Good times!! At least a trans is super easy on FC's.
should he see if he has fluids in reservoir first? then see if slave cylinder is moving..
Johnny_K is offline   Reply With Quote
Old 09-15-2017, 10:20 AM   #350
project86
project86's Avatar
there is fluid.
'90 GTUs
'10 Toyota Prius
Old 09-15-2017, 10:29 AM   #351
A little leak goes a long way, and the level might not be affected enough. It is something that should be done, and takes 2 seconds. lol
Old 09-15-2017, 10:42 AM   #352
project86
project86's Avatar
clearly... which is why I said "there is fluid".
'90 GTUs
'10 Toyota Prius
Old 09-15-2017, 10:52 AM   #353
You weren't specific!! Thought you meant there is fluid in the MC reservoir. Lol.
If there is fluid under the slave cylinder plunger boot, replace it and add an SS clutch line if you don't already have one. They're cheap.
Old 09-15-2017, 10:58 AM   #354
project86
project86's Avatar
Oh I think I misunderstood what you were saying to check. I actually have a new slate and an ss line in my mazdatrix cart. Waiting to hear back from Adler about a flywheel and counter weight.
'90 GTUs
'10 Toyota Prius
Old 09-21-2017, 09:45 AM   #355
project86
project86's Avatar
I think I may have mentioned that I developed an idle surge. I initially had the screw in the top of the TB backed all the way out after the emissions removal and it held around 900RPM.
Lately its been idling around 1500 and surging to 2000 intermittently. So I was reading on the other forum about it and found one thing that said adjust the screw so I screwed it all the way down and it brought it back to around 900-1000. After I started driving it the idle jumped back up to 1500 but didn't surge any more and then settled back down to 900. Still no surge so thats good.
Do you think by BAC could be bad? I know i dont "need" it but it does help with idle speed. I suppose I could unplug it and see how the car responds.
'90 GTUs
'10 Toyota Prius
Old 09-21-2017, 09:55 AM   #356
infernosg
IT'S ALIVE!
infernosg's Avatar
There's a procedure for adjusting this screw in the FSM. IIRC, while idling and warmed up you have to ground one of the pins in the green check connector located elsewhere in the engine bay and then adjust the screw so the TPS voltage is within a certain range.
EDIT: In the '89 FSM it's in section F1. Pages F1-15 and 16 cover idle adjustment, pages F1-40 and 41 cover idle control and checking the BAC, and page F1-83 covers checking the TPS. Found here: http://www.wright-here.net/files/man...mission_NA.pdf
Old 09-21-2017, 09:59 AM   #357
project86
project86's Avatar
It wasn't the TPS I was messing with. That we got adjusted correctly a while ago. I'm referring to the "idle screw" on top of the throttle body/UIM.
'90 GTUs
'10 Toyota Prius
Old 09-21-2017, 10:00 AM   #358
FC Zach
FC Zach's Avatar
^ Yep, you can't just turn the screw one way or the other without making the connection on the test connector.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 09-21-2017, 10:01 AM   #359
FC Zach
FC Zach's Avatar
Kyle, that's what he's taking about. . There's more to it than just turning the screw.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 09-21-2017, 10:02 AM   #360
FC Zach
FC Zach's Avatar
Check your manual.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
