#16 |
Hey this is Logan, I was linked by low impedance. Its always a large debate on 6-port vs. 4-port n/a. I personally feel the 4 port is the way of making power easily, and cheaply. The irons are not expensive, and a used standalone is very cheap as well. Here is my setup of the RE-
Stock upper and lower intake manifold from the 13b-re. Medium sized port, S5 rotors, not ideal header at the time. 1st gen distributer, haltech F10a fuel only computer, 3" k+n filter. MSD box, with second gen coil for leading. Electric fan. 206rwhp with 152rwtq. The power under the curve is great, making more torque at even 1500rpm than a stock GSL-SE. If you guys have any other questions, let me know. I like the forum, so I will be hanging around now
#17 | |
^Welcome GTO and thanks for the info.
#18 | |
Rep Power: 20 ![]() |
#19 | |
.I know for a fact that a S5 n/a 6-port will not gain 50-60rwhp from a standalone install. I would love to think so, but its not possible. The AFM is not super restrictive, a loss of 5-10hp is pretty realistic. Tuning and timing will net another 10-20 or so. I would love for someone with a 6-port to prove me wrong, but they require so much work to get there. The 4 port of any type produces 180+rwhp with so little work. And its hard to make less than 170rwhp even with a stock exhaust mani, and 9.0:1 rotors. In my opinion the 6-port just cant do this. |
#20 | |
So 4 really is greater than 6, go figure...
4>6
#21 | |
#22 |
Rep Power: 21 ![]() |
on the other hand, auto manufacturers aren't looking at just power output.
Once you start porting engines, playing with tuning etc, the fuel economy, drive-ibility, reliability, etc change. Emissions comes into play. The switch from the 4 port 13b to the 6 port 13b was probably just a function of the above. Plus Mazda seems to enjoy experimenting with new ideas.
#23 | |
#24 |
but stock, the ports are rather small as opposed to an a medium to large street port. Porting generally does bad things to most forms of e-check.
#25 |
Emissions, fuel economy, driveability.
People who race high power turbo hondas dont need vtec either, it's just there for driveability, from the factory.
#26 | |
DEFINED AUTOWORKS Where concept meets results Black 1994 FD 4-rotor 610rwhp all motor Red 1970 Mazda R-100 with 10a Black 1974 Mazda Rx4 Black 1984 Gsl-SE 13b-re streetport 230rwhp |
#27 |
so from what i am geting it can be better you just need to be able to tune it right and have the housing ported. it might suffer a little down low but up high it would gain some. Am i correct so it would be almost fesible to do it and see would i would gain or lose. I am just going to be tinkering around with the motors and seeing what would even be able to be reused.
underpowerd and still faster
#28 |
Out of curiosity does anyone have a side by side comparison between the 6 port stock and the 4 port stock (the ports on the irons specifically). I'm curious because I know you can port the 6-port to be much bigger than the 4-port (but you end up killing the intake velocity), but I'm thinking that the 4-port is in a better position for more extreme porting with less negatives associated with it.
#29 |
i might be able to do so in comparing a 12a four port to a GSLSE, and/or S4 6 port. I only have a turbo center iron.
#30 | |
My thinking is that the "no-no" spots or the limits of porting are the same location for the 4 port and 6 port, but I may be mistaken on that.
