Old 08-06-2008, 09:08 PM   #1
Bryan@BNR
Bryan@BNR is on a distinguished road
What type of rear coil overs should I do?
I am setting my 1st gen up from drag and want to see what kind of custom coil overs and spring rate I should use in the rear of the car. I am working on a custom 8.8 rear end.
Bryan@BNR
Bryan@BNR is offline   Reply With Quote
Old 08-06-2008, 11:49 PM   #2
Rogue_Wulff
Non Member
I don't know of any true coilovers for the rear. Solid axle cars tend to have a seperate spring and shock, making coilovers nearly non-existant. The shock mount isn't strong enough to mount a coilover, and there's not much in the spring area to attach one to.
There are a few companies that offer custom springs and an adjustable spring seat, such as ReSpeed.
I cannot help on the spring rate.
Old 08-07-2008, 04:51 AM   #3
Kentetsu
Kentetsu's Avatar
The only option I'm aware of for the rear of the car (now that ISC is no longer producing them) is from www.respeed.com
This is the system that I'm using, and it works very well. You can ask the question about spring rate in the Respeed vendor's section in this forum.
Old 08-07-2008, 12:01 PM   #4
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
I also have the ReSpeed rear set-up. Quality parts, ride-height adjustable, and many spring rate options.
impulsive-RX7 is offline   Reply With Quote
