Old 09-16-2008, 01:29 PM   #1
Where should i put the muffler in the system?
i am thinking at the end, since it may help eliminate the "annoying" tin sounds from the exhaust. but my setup would be easier to run it in the middle before the rear suspension.
Old 09-19-2008, 08:10 AM   #2
So i just put it in the middle, about where the stock cat would go. The magnaflow i used has real good dimensions so clearance to the ground is still very good.
Sound wise? Much much better. Im very please. I still need a new exhaust gasket for the DP to the the rest of the exhaust. Seems to have blown out...
Old 09-25-2008, 02:39 PM   #3
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Having the exhaust go through the muffler sooner in the system is probably better for reducing metallic noise, I'd imagine.
Is this for your FB? Which Magnaflow did you use? I'd like to put something there in a system I'm planning.
Old 09-25-2008, 02:59 PM   #4
this was for my TUrbo II. if you look in the thread for it in the projects section youll see a picture of it. Its a Magnaflow, not sure which model exactly.
