Old 10-08-2008, 09:42 AM   #1
silverfd
Still not fast enough!
silverfd's Avatar
silverfd is on a distinguished road
Hello all!
Hi all, i'm an rx7 fd3s owner living in the UK, just been looking for a set of twin turbos, think they're hitachi H12's?? Looked at ebay and found a guy selling some, and he had a write up about this site, so thought i'd join!
My fd is silver, and was standard when i bought it a year ago, now i have twin air filters and a catback exhaust, changed the headlights to some dual halos, and now i'm looking to really make it run right, and stay that way for a while, i do intend on big power gains, but it is all relevant to cash flow!
Basically my boost pattern seems to be wrong, with the first turbo running a nice 0.9, then drops to around 0.5, just as it should i believe, but the second turbo boosts up to around 0.9 for only a second before dropping to 0.6 til the red line!
I'm relatively new to all this stuff, but willing to listen and learn. I had to replace my sparks last week, although i had replaced them only three months previous, not sure, but could this be oil from turbo two leaking and gumming the plugs up?
If you can help, or even if you just fancy a chat, drop me a message and say hi!
Cheers,
Adam
silverfd is offline   Reply With Quote
Old 10-08-2008, 10:06 AM   #2
SpooledupRacing
Guest
Posts: n/a
Good to have you here thx for joining..
as to yoru question.. If the turbos are blowing oil out the exhaust u would notice it and it wont gum up the plugs.. now if the turbos are blowing oit out the front into the intercooler piping then it is possible some could get fed back in through the intake track and land on the plugs.
remove yrou intercooler pipe from the turbo (both of them) and look for any signs of oil.. if they are clean then u are passing no oil out the front.
are u having problem with oil consumption
I dont know much abotu how the fd's run but is it possible they are spiking to .9 then just settling at .5-.6 if thats the case maybe thats normal. ALSO if they are just .1 different maybe u have better flow out of one exhaust port then the other.. if I remember right the turbos are fed off the same manifold it is possible one will see more exhaust then the other.
Old 10-08-2008, 10:32 AM   #3
87turbo_turtle
Rotary Chic
87turbo_turtle's Avatar
87turbo_turtle is on a distinguished road
welcome
Turtle
Yes I am a girl and I will kick your butt.
Prove yourself.
87turbo_turtle is offline   Reply With Quote
Old 10-08-2008, 11:32 AM   #4
what part of the UK i used to live in london. hence why i'm not allowed to donate blood...
Old 10-10-2008, 05:59 AM   #5
silverfd
silverfd's Avatar
Rotary chic, is that a promise?? hehe
Thanks Spooledup, i'll check and get back to you on the oil situation.
Vex, i'm down in Kent, where are you living now?
Old 10-10-2008, 07:04 AM   #6
SpooledupRacing
Guest
Posts: n/a
Well welcome aboard and I hope u enjoy your stay
Old 10-10-2008, 07:20 AM   #7
silverfd
silverfd's Avatar
y
Old 10-10-2008, 04:02 PM   #8
welcome, have you found the source of your problems?
Old 10-11-2008, 11:31 AM   #9
silverfd
silverfd's Avatar
Oil in my intercooler pipes, looks like turbo rebuild, unless anyone has a cunning plan??
Old 10-11-2008, 12:11 PM   #10
SpooledupRacing
Guest
Posts: n/a
nope sorry to hear sir.. u need a new turbo or have them rebuilt...
when u do the job make sure to clean yrou intercooler pipes AND remove the intercooler and clean it with (I use gasoline) and then water then let it air dry.
the intercooler will have oil gummed up in the bottom of it now..
Old 10-18-2008, 06:55 AM   #11
silverfd
silverfd's Avatar
Thanks for the info/help! Managed to buy a pair of turbos, with some play on the shaft of one of them, also bought some hitachi uprated impellers and shafts, with a 15 degree clip, got it all for about $100 US, so if it doesn't work out i don't mind too much! Keep ya'll posted on how it goes and if i gain any performance with the upgrades!
Old 10-19-2008, 08:31 PM   #12
blwnrtr93
blwnrtr93's Avatar
blwnrtr93 is on a distinguished road
check out BNR here on the forum if you still need a new set of turbos. there are several members here who swear by his turbos.
1993 BB RX-7
2005 Black Mazda 6i
1991 Primer Celica GT
1968 Camo Chevy P/U
Garfinkle's Airpump Idler Pulley: Keep the stock contact patch on your water pump w/o running Airpump!
blwnrtr93 is offline   Reply With Quote
Old 10-19-2008, 09:49 PM   #13
how much oil is in your IC?? If some, i say its ok. I would go thru your vac lines and make sure everything is ok. Look for signs of crack and check your one way valves. Don't look at some residue on your IC piping as sign of bad turbo. Unless you are smoking really REALLY bad and unable to boost correctly, i would not blame on turbos and go thru pain staking time to replace turbos.
Check your shaft place on the turbos that are on and trace all the lines.
Good luck.
Old 10-30-2008, 05:31 AM   #14
silverfd
silverfd's Avatar
lots of oil in the IC pipes, black bumber where it should be silver, and spark plugs keep getting coked up. Where will i find the one way valves? all pipes in the rats nest seem ok!
Old 10-30-2008, 06:58 AM   #15
SpooledupRacing
Guest
Posts: n/a
YEah as I suspected wasted turbo(s) make sure you clean out that IC real good..
