Old 03-10-2008, 11:58 AM   #1
oorx7
oorx7 is on a distinguished road
Ideas for swaps other than a V8.
Personally I am panning on using a 4g64 block in a FD.
What kind of swaps have you guys seen or are doing?
oorx7 is offline   Reply With Quote
Old 03-10-2008, 12:01 PM   #2
The only swap I have personally seen besides the V8 swaps was an SA with a 4.3 Vortech V6...actually was pretty quick little car, but not my cup of tea
Old 03-10-2008, 12:16 PM   #3
oorx7
The chassis that I will be doing a swap on, will be solely used for autocross/road course racing.
One of the swaps I have thought of performing.
Boxer flat four:
The Good; good torque, sits really low in the chassis, fairly light because its aluminum, and might mate up to the RX-7 trans.
The bad; Replacing miner things such as spark plug would be a choir, not as Stout of a motor than other options.
Old 03-10-2008, 12:25 PM   #4
Never thought of that one...but it seems like side clearance would be an issue
Old 03-10-2008, 12:31 PM   #5
The Phantom Gallon
The Phantom Gallon is on a distinguished road
yeah, how wide are those engines?
i'm sure it will fit, but it might be pretty tight. Trans mating might be an issue.
The Phantom Gallon is offline   Reply With Quote
Old 03-10-2008, 12:34 PM   #6
I wouldn't do it on an FD, but still have always thought 2.3l Turbo Ford powered FC would be neat and Granny's already has the mount kit available. Bulletproof engine, takes crazy amounts of boost on stock short block........Only down side is the weight.
Old 03-10-2008, 12:37 PM   #7
oorx7
I measured it up, and unfortunately it was on a piece of paper that I can't find ATM. But there was only about an inch of clearence for the the head to the frame rail on each side, IIRC.
The nice thing was, you just about fit the whole motor behind the shock towers. The idea was to run two small turbos, one on each side. Then mount them in the front, with a V-mount cooling setup.
Old 03-10-2008, 12:38 PM   #8
oorx7
Same thought I have about the 4g blocks.
Old 03-10-2008, 02:41 PM   #9
P71
P71's Avatar
Might want to do some more research Stock blocks/cranks are fine, but pistons and rods are junk. Crack-free heads are drying up. A fully-dressed 2.3T also weighs as much as a 302 (which means it's MORE then an LS1). Good motors, but the market has come and gone on them. You'd have better luck building 12A's or nailhead Buick's honestly...
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
Old 03-10-2008, 08:13 PM   #10
Tinman
Tinman is on a distinguished road
My daily driver is an 89 GTUs fitted with a 3.8V6/T5 combo out of a 98 Camaro. Not a powerful swap but a bit faster than a stock TII, gets 30mpg, and serves well as the weekend tracking car when the V8 car is out of service. There is a pic of it in the 2nd gen. media section.
Tinman is offline   Reply With Quote
Old 03-10-2008, 09:03 PM   #11
My bad...I had a 86 XR4Ti I just sold. When I got it about 4 years ago, most people thought the 2.3Ts were still the shit, but its been a few years since I seriously looked into modding them cause I got the RX instead and my sister started driving the Merkur.
Old 03-11-2008, 02:16 AM   #12
blwnrtr93
blwnrtr93's Avatar
blwnrtr93 is on a distinguished road
There is a thread on 7club that details a Nissan KA24DE swap into a FC. I'm not sure what the status is, but here it is: http://www.rx7club.com/showthread.php?t=542285
1993 BB RX-7
2005 Black Mazda 6i
1991 Primer Celica GT
1968 Camo Chevy P/U
Garfinkle's Airpump Idler Pulley: Keep the stock contact patch on your water pump w/o running Airpump!
blwnrtr93 is offline   Reply With Quote
Old 03-11-2008, 03:46 AM   #13
FD3S-K
FD3S-K's Avatar
FD3S-K is on a distinguished road
sr20
1993 MB RX-7 Touring - GT40R Hybrid,Large Streetport, XXXwhp
"Speed has never killed anyone, suddenly becoming stationary.... that's what gets you."
FD3S-K is offline   Reply With Quote
Old 03-11-2008, 12:07 PM   #14
blwnrtr93
blwnrtr93's Avatar
Also you could swap in a Toyota 3SGTE from a Celica alltrac (GT4), MR2, or Altezza. I know TRD has been using the 3SGTE in the GT500 class of SuperGT to power the Supras.
1993 BB RX-7
2005 Black Mazda 6i
1968 Camo Chevy P/U
Old 03-11-2008, 12:24 PM   #15
oorx7
What side of the motor is the exhaust on, I cant seem to remember.
