Old 12-12-2008, 12:18 PM   #16
Started to pull the motor from the Turbo II last night, hope to get it out of the car completely tomorrow, then break it down this upcoming week sometime and see what i have going on inside.
Already have two good housings lined up though.
Old 12-14-2008, 10:19 PM   #17
Fidelity101
Reliable Source
Fidelity101's Avatar
Originally Posted by 12arotary View Post
whats with this haha i'm 6'4" too and I fit comfortably in
my 82... I hate driving my fc cause my head is too
close to the ceiling fb is far more comfortable
You must be tall bodied and short leg, I'm the opposite. Long legs and a short torso.
My Rx-7 Vids
Old 12-17-2008, 03:11 PM   #18
i have heard conflicting info on 1/2 bridges and streetports regarding them being essentially the same in power output in a naturally aspirated situation. Any one have more info on this.
Old 12-17-2008, 05:05 PM   #19
drewski86
Slow
drewski86 is on a distinguished road
They are very similar as far as power output in N/A applications, but you still get the poor drivability with the half bridge. If you plan on going half bridge, you might as well go full bridge. If you have the resources you might as well go PP instead of full bridge. PP will make more power and actually be milder down low as bridge ports usually have more overlap. Once you get into high overlap ports, free flowing exhaust becomes VERY important. Power falls off hard as you try to muffle it and there will come a point where a streetport will make more power at the same db level.
drewski86 is offline   Reply With Quote
Old 12-18-2008, 08:35 PM   #20
PP is actually in the line up for the next engine i build unless i start feeling spunky and just opt to do it with this one. Might try to kill the some 6PI irons then if i am going that route. I know people opt for the four ports because there is less port to fill. Or maybe ill try the racing beat aluminum end plates?
Old 01-25-2009, 11:44 PM   #21
JunpoweR
JunpoweR is an unknown quantity at this point
Balla!
--^v--JunpoweR--^v--
"90 GTUs Crystal White *GT35 WB TA Project*
"90 GTUs Brilliant Black *Restoration*
1984 GSL-SE *Daily*
JunpoweR is offline   Reply With Quote
Old 01-28-2009, 09:00 PM   #22
well i think im going to try to still put an NA motor into the turbo II to get her running til i can do something else with it. But i want to make something i can transfer to a first gen chassis down the road. SO once i get done with tech school and have some funds, ill start to be able to play.
Old 02-20-2009, 03:00 AM   #23
so does anyone have any interest in seeing what kind of max power people can pull. Maybe do a contest and the top person gets a interview section in the digizine or something. Not to be like the other thread on Rx7club, but i think its a great concept. I would love to see something similar for the 12a as well. Probably limit it to street porting.
Old 02-22-2009, 02:54 AM   #24
i have always wanted to see what a 4 port N/A with ITB's and a MOTEC could do, I bet it could do lots with the right tuner and engine builder, but it seems like one one worth while, like judge ito, or Racing beat, or mazdatrix has tried the setup with their professional experience, or at least not documented publicly.
Old 02-22-2009, 03:40 PM   #25
nissanconvert
nissanconvert is on a distinguished road
Try to source some variable length runners too. Drive them on an RPM output. You'd have to spend hours on a dyno but the results could be impressive.
nissanconvert is offline   Reply With Quote
Old 02-22-2009, 04:59 PM   #26
does anyone actually produce such an item? I mean i have ideas how i would make something work for a naturally aspirated engine but i lack some of the tools needed to make one.
Old 02-22-2009, 05:09 PM   #27
B.Purdy
B.Purdy is on a distinguished road
Fuel Pump
Hey my name is Bennett,
I'm looking for an electric fuel pump for a 86' RX7 13 B.
If anyone has any information about this I would really appreciate it.
Thanks!
Ben
B.Purdy is offline   Reply With Quote
Old 02-22-2009, 10:09 PM   #28
nissanconvert
well, the honda kids source their itbs from motorcycles. I know the R1 has variable length runners, but i'm not sure how much.
This video of the 787b shows the runners operating @ about 4:50
Old 02-22-2009, 11:40 PM   #29
well the MS site has a good thread of throttle bodies from motorcycles. Maybe ill pick something up off ebay and see what the deal is
http://www.msefi.com/viewtopic.php?f=29&t=6627
Old 03-02-2009, 11:03 PM   #30
well i am in motion on my project.
13B s4 stock port as the base for now.
going to run an MS unit and a 12a dizzy.
Ill get some baseline info here soon once parts come in and i get the motor running.
What i am curious about is what i can do to the dizzy to make some more power? What is way to go with the split timing? Any other advice?
