Old 04-14-2009, 07:24 PM   #16
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Originally Posted by proz07 View Post
lol i think alot of us are waiting to see if it works, just dont want to do it ourselves yet.
z
LOL, yep. If no one does it within the next ~3 months, I may step up to the plate. But I sure hope someone does it before then.
Old 04-15-2009, 12:06 AM   #17
I did order one, but I'm deployed right now. I'm going home in about a month so don't fret guys, I'm gonna get it done and let you all know how it goes, haha. I'll post up where I mount it and if I used any adapters and all that. I'm sure I'll have to get adapters because it's a Motorola terminal and I don't think those fit in our stereos from what I've heard. But I have an Alpine so I'm not sure yet. I will post in about a month though.
Old 04-15-2009, 12:30 AM   #18
i plan on going this route as well. I have the "antenna is stuck in the raised position" look and i hate it.
Old 04-15-2009, 12:58 AM   #19
Shouldn't need one. Motorola is a standard connection for car radio antenna
Old 04-15-2009, 07:59 AM   #20
OK Alex, let us know how that goes then, haha.
Awesome, well hopefully that will be the case here. Now I just have to decide where to hide it.
Old 04-15-2009, 08:06 AM   #21
i have a feeling we will see how yours works first. I have only 12 days til i leave for basic.
Old 04-15-2009, 10:21 AM   #22
$100T2
Big Daddy
$100T2's Avatar
Originally Posted by Max777 View Post
dude, this is rad! I removed my ghetto power antenna, as well as all the wiring to it because it broke. This is so much simpler, I am going to purchase one and put it in the glove box or somethin.
I'd run it behind the hatch above the taillights.
Old 04-15-2009, 01:48 PM   #23
double post
Old 04-15-2009, 01:49 PM   #24
Oh yeah, I forgot about that haha. Well get on it and get it done before you leave! HAHA. Good luck with that too man.
So I've been thinking about where to hide this antenna. I was thinking about laying it across the rear harness bar and wondering if that would help reception, basically making it a bigger antenna, but I'm not sure if it will work like that.
Old 04-24-2009, 07:42 PM   #25
muibubbles
Bubble Tech
muibubbles's Avatar
muibubbles is on a distinguished road
i had hidden one but fcked up the wires when i tried extending it... i think hiding it under the headliner is the best.. either front or rear.//
muibubbles is offline   Reply With Quote
Old 09-10-2009, 03:25 PM   #26
http://www.ecshylites.com/catalog/it...191/368049.htm
I forgot all about this. I bought the one in the link and installed it a couple months ago. At first I just removed my stock antenna and disconnected the cable going to the stock one. It was a male end, and I connected it with the male end of the hidden antenna using a female/female RCA adapter. However, the adapter was kinda loose so I taped around it...I know, ghetto. It worked, but it seemed like there might have been a little static. Although I have new door speakers too so it could be that, who knows. I also didn't have AM.
Recently I just bought an extension cable for the antenna wire because my stock wire was screwed up on the stereo end anyway. So I ditched the stock wiring and adapter and hooked everything up correctly. Unfortunately I've had the car apart again since then so I haven't tried it to see if anything changed. I'll post up when I do.
Old 09-10-2009, 05:03 PM   #27
proz07
Needing a new tow rig.
proz07's Avatar
not bad lots of static or little scale 1-10? and did you try different mounting positions area's? where did you have it mounted? in a fb/fc/fd?
z
Old 09-10-2009, 05:07 PM   #28
Oh just a very little bit of static, barely noticeable. I forgot to mention where I mounted it. It's an FD, and I put it all the way in the rear of the hatch, behind the plastic. I didn't actually mount it to anything, I just have it laying in there.
Old 09-10-2009, 07:56 PM   #29
proz07
proz07's Avatar
gotcha so in your opinion worth the 40ish?
z
Old 09-11-2009, 08:29 AM   #30
Well, considering I pulled my stock one and had the hole filled in during body work and paint...absolutely hahaha. Actually I do think it's worth it regardless though. Like I said, I haven't seen whether I get AM yet (there is one talk station I listen to, so I'd like to have it), and I think there MIGHT have been one FM station I didn't get that I normally listen to, which is kinda odd, but it's a good antenna from what I can tell. The stations come in really clear.
