Old 04-20-2009, 05:34 PM   #1
My FC is chugging along (not good)
On the way to DGRR my FC began to miss a little, then the exhaust started to sound weird and it was losing power. We tore out the plugs and did a poor mans compression test. Both rotors sounded strong. Checked coolant and oil, neither are intermixed. Checked spark and its all good. Even put new plugs in.
I was getting a CEL flicker when it started acting up. And I get boost (although the needle is shaky). A few people at DGRR said to look into fuel issues. So before I go this weekend to attempt a resurrection, I would like some input.
S5 TII, no emissions, stock ECU with an FCD. Full exhaust, FD pump.
Here is a vid:
Old 04-20-2009, 10:34 PM   #2
your running on one rotor it sounds like. I'd check the rear housing to see what's going on there.
Old 04-20-2009, 10:54 PM   #3
sorry man that sounds horrible....compression check?
Old 04-20-2009, 11:46 PM   #4
IH8DSM
IH8DSM's Avatar
if it was fuel i wouldnt think it would run at all, or at least idle then die. If it was a intake or exhaust gasket it would run like crap or not at all. Ive never experienced a down rotor so im not sure on that one.
Old 04-20-2009, 11:47 PM   #5
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Ditto. Just because both rotors have good compression does not mean that both are getting fuel right. Having good compression, and the sound of that video i would say you have wiring or fuel issues killing one of your rotors. I would still try to get some real compression numbers though.
Old 04-20-2009, 11:50 PM   #6
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
A wiring issue could cause one of the rotors injectors to act up, or bad injectors, or clogged, and so on and so on. Checked for vacuum leaks??
Old 04-21-2009, 01:06 AM   #7
The needle for the boost gauge *shouldn't* be shakey either. That would imply some sort of possible electrical issue. Might not be the direct cause of whats happening. Could just be something else.
Have you confirmed timing? Also, get your hands on a piston compression tester, have someone crank the car and hold the shreader valve open so you can watch the faces.
Old 04-21-2009, 06:48 AM   #8
When I free rev it, the boost gauge pulls down vacuum pretty hard. When I try to drive, it will go into boost, put the engine misses and sputters so the boost is shaky.
It is getting spark (ask Paul....he knows). I am hoping it is something simple, but I will not know until this weekend when I can get back to it. I plan on bringing a compression gauge along as well. I don't think it is *blown* since I have experience with a blown engine.
Old 04-21-2009, 07:16 AM   #9
My5ABaby
My5ABaby's Avatar
I'm not sure I believe it's getting spark. I think we need a video of Paul testing it.
Community Service Manual
RotorWiki
Old 04-21-2009, 08:47 AM   #10
Boostmaniac
That horrible hammering sound, god that sounds nasty. Obviously related to engine speed.
I got nothing on this one that would be deemed "good news".
Old 04-21-2009, 08:59 AM   #11
Anyone think it threw a bearing?
I plan to bring a set of coils, injectors, test the wiring, compression (with a tester).
Another idea Kevin had was maybe it knocked and chewed up the corner seals.
Old 04-21-2009, 10:16 AM   #12
Fuckit. Towing it home this weekend. Reservation has been made. I am not going to try to do a driveway repair on my baby.
Old 04-21-2009, 11:19 AM   #13
so you are going to tow it home and repair it in your own driveway?? lol
I'm not testing for spark again.
Old 04-21-2009, 11:34 AM   #14
Garage bitch.
Old 04-21-2009, 12:54 PM   #15
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
garage huh? well arent you special, ive been laying out in the mud for the past 2 days working on mine lol. seriously though good luck and i hope its something simple.
