Old 11-16-2009, 05:51 PM   #1
Pro ViZion
Run DAMN YOU!!!
Pro ViZion's Avatar
Pro ViZion is on a distinguished road
Question Huge Idiling and Stutter Issue!
OK so I own an '84 GSL-SE. I have a huge problem with cold starts.
When I start the car it likes to shoot a bellowing white cloud out of my exhaust continuously until the car warms up and then no problem.
I'm guessing i have some kind of coolant seal issue because there is no more white smoke once the engine is up to temperature. The seal is much better then. I would like to know a reason for this and a possible fix for my problem.
Also while driving the car once i get to or past 3k rpm it likes to stutter.
Lets say if I were to be driving in second get completely off of the clutch and floor it, Nothing happens. I have no idea what is wrong with it at this point. everything up until around 3k is fine but not there after.
The car has 150,000 miles. Aftermarket intake and RB headers and no air pump if that can give any kind of problems.
Thanks in advance.
www.VegasRotary.com - Vegas' local rotary car community!
Pro ViZion is offline   Reply With Quote
Old 11-16-2009, 07:29 PM   #2
what are the plugs looking like?
i would believe the coolant seal issue to be correct.
Old 11-16-2009, 08:22 PM   #3
Pro ViZion
Run DAMN YOU!!!
Pro ViZion's Avatar
Brand new plugs. Replaced them last night. Old ones were done from all the cranking.
Do you have any idea what would cause it to have no power past 3k rpm. I have a feeling it just might not be getting fuel because it stutters at 3k and past that is nothing.
Old 11-16-2009, 08:31 PM   #4
how long have you owned the car, did it sit for any length of time?
Old 11-16-2009, 09:00 PM   #5
Pro ViZion
Run DAMN YOU!!!
Pro ViZion's Avatar
Its sat for like 2 years.
Old 11-16-2009, 09:03 PM   #6
BigIslandSevens
BigIslandSevens's Avatar
First thing you need to do is get a good manual and replace all of the vaccum lines with new ones so you know that they are in good shape. Do one at a time so they don't get mixed up. Then you need to start troubleshooting the FI system. There are alot of things that help or hurt the idle control. A good write up I found a while ago is this one.I think I saved it from the other forum. Hope that doesn't cause any issues.
http://fm.no-ip.com/gslseidle.html
Old 11-16-2009, 09:45 PM   #7
Pro ViZion
Run DAMN YOU!!!
Pro ViZion's Avatar
Thanks for the good info I'll be looking into that.
Old 11-17-2009, 08:02 PM   #8
well if the car sat for an extended time i would check the fuel system. might not be able to get enough fuel from something being clogged. Check the filter first, operation of the injectors second.
Old 11-18-2009, 03:35 PM   #9
Pro ViZion
Run DAMN YOU!!!
Pro ViZion's Avatar
Yeah I have replaced the fuel filter with a mazda oem one but I have still been running it on bad gas. Ill be going through that this weekend.
Gonna drop the tank, clean it out and get some good stuff in there.
Checked timing and not sure which dot on the pulley needs to be lined up for tdc. Both of the dots have no color anymore.
Old 11-19-2009, 05:35 PM   #10
rx4ur7
Rotary since 1972
rx4ur7's Avatar
White smoke is water. Do the engine seal check. Start with cap off radiator, if it bubbles afraid you have a seal gone.
Old 12-13-2009, 09:00 PM   #11
1stGenNutt
1stGenNutt is on a distinguished road
white smoke is not always water .. smell it, taste it, love it!!
1stGenNutt is offline   Reply With Quote
Old 12-17-2009, 02:07 PM   #12
brycerxer
brycerxer's Avatar
brycerxer is on a distinguished road
Did you check compression? Sounds like if it's not the fuel, it might be running on one rotor. Take the top two plugs out, one at a time, and turn it over by hand and see if you get 3 strong puffs of air from each rotor.
'85 RX-7 GSL-SE Current Driver
'85 RX-7 GS Current project
'84 RX-7 Parts car-SOLD
'91 RX-7 VERT SOLD
brycerxer is offline   Reply With Quote
Old 01-07-2010, 01:26 PM   #13
Pro ViZion
Run DAMN YOU!!!
Pro ViZion's Avatar
I checked compression and the puffs are very consistent and strong on each rotor.
