Old 11-30-2009, 09:54 AM   #1
Rotorypolo
Rotorypolo's Avatar
Rotorypolo is on a distinguished road
Premix & Holley fuel pump
Has anybody experience running premix in the tank with Holley Red? I just recently noticed a leak around the body if the pump and not sure premix will cause leaking?? The pump is fairly new. I wonder if these pumps are not suitable to run with permix. Thanks s bunch
1994 RX-7 PEP - (SOLD)
1993 RX-7 R1 - (under the knife)
1973 RX-3 13b 5 speed (DGRR 2011- 1st in class)
Rotorypolo is offline   Reply With Quote
Old 12-01-2009, 01:00 AM   #2
Kentetsu
Kentetsu's Avatar
This is the second thread on this topic that I've seen in the last few days. Someone mentioned that the Holley fuel pumps seem to be prone to leaks. I don't think I'd blame this on premix. Good luck...
Old 12-03-2009, 01:41 AM   #3
FC Zach
FC Zach's Avatar
I've used the Holley set up on a friends car and there weren't any problems with the pump. I have run a Summit Racing kit before on my own car that is styled similar to either an Aeromotive or a Holley (not too sure since I've changed my mind so much) and had no problem with leaks.
Is this going on your RX-3 or another car?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 12-04-2009, 02:53 AM   #4
IH8DSM
IH8DSM's Avatar
ive got a holley fuel pump in my carb'd 7 with no problems
Old 12-04-2009, 08:29 PM   #5
Rotorypolo
Rotorypolo's Avatar
Are you guys running premix in the fuel with the Holley pump??
Old 12-05-2009, 12:35 AM   #6
reaper
2slow4u
reaper's Avatar
reaper is on a distinguished road
this is something i've been wanting to know aswell, i;ve been looking into a holly black
my hoarse is amazing
sincityrotary.com
a place for las vegas rotary enthusiasts
reaper is offline   Reply With Quote
Old 12-05-2009, 09:28 AM   #7
Rotorypolo
Rotorypolo's Avatar
I have contacted Holley USA, and they were unable to verify the compatibility of their pump with Premixes. They said the content inside these fuel might potentially Flood the seals and causing leakage around the housing and is not rebuildable.
Old 12-05-2009, 02:56 PM   #8
FC Zach
FC Zach's Avatar
I do and I think IH8DSM does as well
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 12-05-2009, 03:57 PM   #9
Rogue_Wulff
Non Member
What type of premix are you using?
Running a FPR? Return style, or dead-headed?
I cannot see how premix would damage the seals, since they are supposedly able to withstand gasoline. If anything, the premix should actually reduce wear inside the pump, since it would allow lubrication of anything that is exposed to the fuel.
Dead-headed systems can actually cause the pump to run hot, since the fuel flowing thru it is not moving as quickly as a return style system. The fuel flow helps to cool the pump. A pump that gets hotter, is more likely to have problems over the same pump in a system that allows the pump to run cooler.
Also, with more fuel supplies becoming tainted with ethanol, more fuel pumps are damaged by the corrosive effects of the ethanol.
Old 12-06-2009, 11:37 PM   #10
IH8DSM
IH8DSM's Avatar
I run it with my gas and im just running a mr gasket fpr, and im just running cheap premix from wally world. comes in a blue jug 2 storke oil
Old 05-14-2010, 08:30 PM   #11
jr515
brap brap
jr515 is on a distinguished road
how may ounces per gallon?
jr515 is offline   Reply With Quote
Old 05-15-2010, 08:38 AM   #12
FC Zach
FC Zach's Avatar
1 oz per gallon if there isn't a MOP currently on the vehicle.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 05-16-2010, 01:17 AM   #13
jfaplanet
jfaplanet is on a distinguished road
Premix
I've backed down from 1 oz per gallon to 1/2 oz per gallon in the REPU, as has IH8DSM. 1 oz seemed to cause too much smoke. But I got away from the Holley because it was too loud. Running the Mr. Gasket pump now without any problems.
jfaplanet is offline   Reply With Quote
Old 06-02-2010, 08:59 PM   #14
fire85gslse
fire85gslse's Avatar
Dont sound like a premix issue at all. I personally dont like the holley red (too loud). Mr Gasket is the way to go. Cheap and good quality
