Old 11-03-2008, 06:31 PM   #1
BLKTOPTRVL
BLKTOPTRVL's Avatar
BLKTOPTRVL is on a distinguished road
Slid engine back in...
Didn't want the engine sitting on the stand much longer, so I hoisted it back into the bay.
Here is the blow-by-blow, I:
  1. put the exhaust mani on
  2. put the mounts back on
  3. put the P-Plate on and aligned it.
  4. hoisted it into position
  5. re-jacked the tranny - it had sagged down over the months.
  6. realized the rear lift bracket was on backwards. Let the engine sit on the frame while flipping the bracket
  7. got the long bolt through the bracket into the tranny
  8. shoved and changed the balance on the hoist until the engine fell into the bell housing
  9. spun the e-shaft until it locked in place (tranny in gear)
  10. put the long starter bolt through the passenger side top hole to align
  11. at this point, I couldn't get the engine to clear the steering, so I removed the driver side engine mount
  12. hoisted down and adjusted the engine until I could get a bolt into the top driver side
That is how it sits now. After I get home from voting tomorrow, I will try to get the rest of the bolts in and reinstall the driver side motor mount.
Hopefully the rest will go as smooth as that above. I'm really surprised I had no trouble so far doing it by myself.
...shoot a mother-humpin moose, eight days of the week...
BLKTOPTRVL is offline   Reply With Quote
Old 11-03-2008, 07:20 PM   #2
Sounds good. Its always more a pain when you put the engine in when the trans is already in place.
Got pics???
Old 11-03-2008, 08:00 PM   #3
BLKTOPTRVL
BLKTOPTRVL's Avatar
OK, I just took this one.
Old 11-05-2008, 02:43 PM   #4
BLKTOPTRVL
BLKTOPTRVL's Avatar
OK, engine is sitting back in the bay, the tranny is bolted tight and to car is once again on 4 wheels.
But the intake is not on, I will bolt it up today.
Question.
The car is going to sit for another 6 months before I finish buttoning it up, should I squirt oil into the chambers and rotate the engine before I install the intake mani?
Old 11-05-2008, 03:56 PM   #5
Its always a good measure. It wont hurt it - just use some good clean motor oil and you should be good. If you use to much, it'll just be harder to start the first time and smoke a bit, but it wont hurt it.
Old 11-06-2008, 03:41 PM   #6
87turbo_turtle
Rotary Chic
87turbo_turtle's Avatar
87turbo_turtle is on a distinguished road
Got pics???
we find it easier at my house
Turtle
Yes I am a girl and I will kick your butt.
Prove yourself.
87turbo_turtle is offline   Reply With Quote
Old 11-06-2008, 03:58 PM   #7
rx7 FC TII
rx7 FC TII's Avatar
looking good. keep up the work.
i wish my engine bay was that clean.
Old 11-06-2008, 04:15 PM   #8
You find it easier to put the engine in when the trans is already in place??
With engine and trans together, all you need to do is slide it into the tunnel, bolt in the mounts and slide the driveshaft into place. Lot less bolts to be involved with
Old 11-06-2008, 07:50 PM   #9
BLKTOPTRVL
BLKTOPTRVL's Avatar
I found it easy because I never even had to get under the car.
Old 11-15-2008, 02:06 AM   #10
Ender
rotors excite me
Ender's Avatar
we have the same load leveler! ^_^
So why will it sit for so long?
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 12-01-2009, 12:40 PM   #11
BLKTOPTRVL
BLKTOPTRVL's Avatar
Sorry to take so long to reply...
It had to sit for about a year because I travel for a living and had to leave the state.
