Old 01-01-2011, 12:02 AM   #16
nate
Not a fan of rust...
nate's Avatar
nate is on a distinguished road
Good progress. Much rust on the underbody?
88 vert
87 SE
nate is offline   Reply With Quote
Old 01-01-2011, 07:32 PM   #17
Pettersen
No, the underbody was done by the last owner, and from what i can tell the only place there is rust under the car is on the rear tow hook
I tried the mig today, probably going to take a little while before i'm good enough to weld anything on the car tho.
Old 01-16-2011, 07:00 PM   #18
Pettersen
Gas tank is out, so now i can start prepping and welding
Also took of the entire exhaust to get rid of all leaks, and to get rid of the tension in the downpipe.
Old 01-26-2011, 08:10 AM   #19
Pettersen
Welded up everything that had to be welded, but my dad wants the garage back since he wants it for his new car :/ so i haveto start putting the car back togheter, and postpone the full restoration until i have a place of my own.
Anyway, New stuff from mazdatrix
Gasket for oil pan, defroster covers, spark plugs, fuel filter with mountings, rotary key ring and some mazdatrix stuff + candy
Old 01-28-2011, 06:20 PM   #20
Pettersen
Some parts for the downpipe/wastegate arrived today
Old 03-02-2011, 09:10 AM   #21
Pettersen
More parts
Turbo timer (previous owner installed a non watercooled turbo :/ )
Banzai racing oil pan brace
TCS rear camber adjuster
Greddy elbow
Old 03-12-2011, 04:33 PM   #22
Pettersen
Finally got time to work a little on the car, installed most of the interior, removed fuel lines and changed fuel filter.
Only got pictures of the interior tho.
(FC guys know why i took this pic )
Old 04-10-2011, 11:05 AM   #23
Pettersen
Got the exhaust all welded up, only need to change oil, oilgasket and mount the banzai oil pan brace before i'm ready for emission testing
Feels realy good firing it up again
http://www.youtube.com/watch?v=upYfMjkfiqk
Old 04-19-2011, 03:21 PM   #24
Pettersen
Made a buttplug for the exhaust, it's only a temporary solution until i can either modify or make a new exhaust.
But the sound is much lower, so it's livable inside the car now, + it's easy to remove for trackdays and general spirited driving
http://www.youtube.com/watch?v=xtujp6dypM0
Old 04-21-2011, 02:43 AM   #25
Pettersen
Originally Posted by Max777 View Post
Something about the extra amount of flow compared to the stock turbo at the same pressure level, causing it to go a bit lean. Do you have a Wide Band oxygen sensor to monitor the AFR ratios? I'm curious about how the afr's look under load.
Really, I'm just amazed to see this setup work, didn't know it was possible to run a different turbo w/o a standalone.
Just mounted a wide band, the car doesn't have plates on it now, so i just have idle numbers. It runs a bit rich to say the least, 10-10.5 AFR on idle. Will post numbers i get under load when i get it on the road again
Old 04-22-2011, 12:09 PM   #26
Pettersen
Made a temporary holder for my gauges.
And finally fixed the oil leak, put in a new gasket and a oil pan brace with studs,
Old 05-14-2011, 05:04 PM   #27
Pettersen
Mounted some "styling" on the rear tow hook
Old 05-24-2011, 05:58 AM   #28
Pettersen
Bought some different wires and accesories to clean up the engine bay, the gauge holder is for my Neon. Looking forward to getting started working on my car's, summer vacation FTW
Old 05-24-2011, 06:20 AM   #29
Thumper
Backyard Mechanic
Thumper's Avatar
Thumper is on a distinguished road
Looks good, was it a pain to put in that oil pan brace with the engine installed? I have one that i still need to install.
Thumper is offline   Reply With Quote
Old 05-24-2011, 06:51 AM   #30
Pettersen
Well i was in a garage with a garage pit, and i had help. But no it wasn't to difficult, just as long as you support the engine properly so it doesn't move when you take off the engine mount. The first time i had a jack underneath but the engine still shifted enough to make it a pita to get the engine mount back on, and with the engine further down the studs where almost impossible to get in some places, so i used some 2"4" and supported the engine from the top and it didn't move at all.
You can use an allen key on most of the studs, but on the front row i used two nuts thightened agains each other, and a little ratchet with and extender and a angle thingy(picture i don't know what it's called in english), it's a bit fiddly but it's doable.
Also a warning, it's probably not possible to get the oil pan on without scratching agaisnt the studs, so i had the sealent on the block, not the pan.
