		#16 |
				Rep Power: 18 ![]()  |
			If you are using the stock oil pan with drilled out holes then the brace is for you .The holes have made the pan rail weak and the brace willimprove things .The holes in the brace will to be drilled out as well .The brace is 3/16 thick and will still reinforce the pan to keep it from distorting .
		#17 |
			 ZooM ZooM!!
			Will this work well with stock oil pan and no modifications (I have a leakage >.<)  Please let me know for I will paypal once confirmed.  Thanks in advance.
	p.s. Please pm for I dont check the forum alot nowadays. Thanks again. -AzEKnightz  |
		#18 |
			Pm  to you and yes this will work on stock pans .Most people have stock pans ,some with studs and nuts . The groove cut in my brace is the feature that lets the brace do its job ,with out the groove the brace will not contact the pan rails width fully.
		#19 |
				Rep Power: 19 ![]()  |
			These are a great brace. Once I installed mine I understood why this is the better brace out there.
			Man, am I lucky to have a friend like David living so close to me and makes great products for my RX7's
	I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit)  |
		#20 |
				Rep Power: 0 ![]()  |
			Is the oil pan brace still available? I have a leaking oil pan and would be interested in getting one.
		#21 |
			THERE are a few ready to go
		#22 |
			I'd like to order one ASAP, I shall PM you with details
		#23 |
			I have received certain products from David my self and i can tell you first hand he takes pride on what he does and the parts are top notch.
	Hit em and run plumbing  |
		#24 |
			I have a new batch ready to ship with the bolts and o-ring The price of the steel went up but the price will be the same .
		#25 |
			Very much interested in one, how much and where do I send money???
			Also what does the kit include and where can I see one??? PM or email me: red93r2@sbcglobal.net Last edited by Red Baron; 05-17-2010 at 03:58 PM.  |
		#26 |
			They are $125  includes shipping $129 paypal .Includes high grade longer pan bolts (19) and longer motor mount bolts (6) . This is the only one with a milled groove to clear the pinch rail on the stock pan,so full presure is applied to the pan .
		#27 |
				Rep Power: 20 ![]()  |
			I want to pick up one of these.  What is your paypal?
		#28 |
		#29 |
			Anyone have pics ??
		#30 |
			I think Howard Coleman does ,he uses  them on the engines he builds .This is the only brace with a milled groove to fit over the pans pinch rail so full pressure is given across the rail .I  drill the two missing holes in the late model pans and use all 19 ( included ) 6mm bolts .I notch the motor mount to clear the new bolt head . The motor mount bolts and the oil level sensor o-ring come with it as well .
