Old 02-14-2011, 12:19 PM   #31
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Originally Posted by My5ABaby View Post
Ah, the BAW thread(s). I looked once, thought it was stupid, and never looked back.
You just need to believe in the love that exists between 2 dudes and you'll fit right in
Old 02-14-2011, 02:20 PM   #32
Originally Posted by Force13b View Post
I use a 3bar GM Map sensor. I don't even know what an Emap sensor is that some fancy Motec thing?
Exhaust
Manifold
Absolute
Pressure
Talk to Glennypoo about it... as I'm assuming he's the one that talked you into the FPSI
Bite your tongue, it can be quite fun.
Old 02-14-2011, 06:11 PM   #33
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Exhaust
Manifold
Absolute
Pressure
Again with the acronyms. I'm guessing FPSI is fuel pressure and actually he didn't. When i setup my fuel system i got done setting the 40psi at idle and shut the hood and thought lota good that gauge does. Did some reading found the pick up and ran some wires.
As for EMAP i honestly don't know what that would do for me. Enlighten me o mighty one. As long as i can get a 0-5v pickup i'm sure i could wire it into the haltech
Old 02-14-2011, 10:04 PM   #34
diabolical1
I have radioactive semen
The FD's stock plastic door handles suck big floppy donkey dick.
why don't you go for broke and say how you REALLY feel about them?
Old 02-15-2011, 12:38 AM   #35
Acrynoms are good... get up on them YLCSP
EMAP is nice for tuning for a few reasons.... specifically for you and I, it allows us to see a better place to run the transition. There comes a point when the EMAP gets so high the turbo's are basically a cork in the exhaust killing power. Using the EMAP to set the transition allows for tuning a smoother one.
EMAP is also nice for tuning timing and you can use it to trim fuel while cruising.... but that's fancy Motec shit
My EMAP sensor is the same as yours and my MAP sensor, just plumbed differently
Old 02-15-2011, 10:59 AM   #36
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Acronyms sucks i work for a DoD contractor i hear enough of them at work.
I'm not sequential so i don't have a transition. But i see what your saying. So you run a basic 3bar GM MAP but run what a braided line from your DP into it?
Old 02-15-2011, 11:00 AM   #37
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
I could have gone with suck 90yr old saggy testicles
Old 02-15-2011, 12:01 PM   #38
Why bother with twins if they're non-sequential? I've been there and yeah its smooth, but damn that kick in the ass <2.5k is awesome
Running EMAP in the DP could be useful info, but it wouldn't help with the tuning aspect of it, the line needs to be pre-turbo. I've got an SS 1/8" to -3 adapter threaded into the manifold. From there I've got 2' of SS brake line. At the end of that is a female -3. Then 8" of -3 braided with a male crimped on one end, and a female on the other. The MAP sensor is mounted in a billet mount threaded for 1/8" npt, so you just thread your adapter in there and the braided line screws on. The nipple on the actual sensor presses into an o-ring in the mount, trick little piecem eliminates all the fluctuations and shit you get from vaccuum tubing and the chances of the line getting pierced or blowing off are basically nill.
Old 02-15-2011, 12:30 PM   #39
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
sequential is fine... as long as you never spool the 2nd turbo... but after you play above 4000 (4500??) WOT, one turbo between 2500 -> 4000 (4500??) is just lag!!!
and of course, if you happen to be partial throttle... because, i dont know, you're playing in the mountains, you hit the tranisition point of the turbos and you don't have enough exhaust flow so you go from 7-8 lbs on one turbo to 0 LBS! on both turbos..and the car falls on its face...
and let's not even talk about what happens when your in the middle of a curve and the 2nd turbo decides it's time to spool!!! previous owner's hubby got a little scared when i did that... twice...
Old 02-15-2011, 01:10 PM   #40
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Because i couldn't afford a single at the time
I don't know if i'm sophisticated enough to pull something like that off. Perhaps something i'll look into when i get to single turboing the car
Old 02-15-2011, 01:30 PM   #41
I dunno what you're talking about... I never once had those problems playing in the mountains. If you're a good little boy I'll let you play too
Piece of cake man, when it's time, lemme know.... very easy to do
Old 02-15-2011, 03:12 PM   #42
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
guess you were going too slow and are too low in your RPMs to have it be an issue =]
Old 02-15-2011, 05:51 PM   #43
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Will do. Hopefully the haltech will have enough input spots for all this...and don't even say go Motec a 5k ecu is not an option
OH SNAP!
Old 02-15-2011, 07:17 PM   #44
Do an M84... its only a $2500 ecu
Pffffft.... maybe I just didn't need boost to keep up with you
Old 02-15-2011, 11:02 PM   #45
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
i was on bald tires... and doing the speed limit because i dont like giving $$ to TN...
