| Carburetors and Carb Tuning.. All info about old school carb set ups.. |
|  04-08-2011, 12:51 PM | #1 |
| Ask Me About My WANKEL!!! Join Date: Jan 2010 Location: Missouri
				Rep Power: 16  |  RB Holley setup, Carb and Dizzy Tuning Help
			1984 12a think its street port but not sure, 465 cfm holley. header back single exhaust, upgraded coils. Where do the vaccum advances get vaccum from and do one or both need to be hooked up rb says trailing only but that sounds wrong. also how do i setup the carb correctly (tune it) and what timing should i be runing. Right now car wont ideal under 1500 and wont cold idle. Any help is greatly appreciated.
				__________________ 1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels 1988 Rx7 Se - Sold 1988 Rx7 GXL - Sold   |
|  04-09-2011, 01:32 AM | #2 | |
| RCC Loves Me Not You Join Date: Mar 2008 Location: Eagleville, TN
				Rep Power: 20  | Quote:
				__________________ 1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 | |
|  04-09-2011, 07:02 AM | #3 |
| RCC Contributor Join Date: Mar 2008
				Rep Power: 18  |
			What zach said also have a set or two of spare leading plugs you'll need em when you start tuning. Also your rb Holley should have a DVD with it(mine did anyways) that tells you how to set the floats change the jets etc. Also while tuning look at the plugs and it'll give you a idea how rich/lean your running As for the vacuum advances I know several people that don't run them so I'd say f it haha.
				__________________  85 rx7 gsl-se - AA tags/ never ending project will never run |
|  04-09-2011, 09:20 AM | #4 |
				Rep Power: 16  |
			i set the timing at 0 degrees at idle with vaccum advance hooked to both advances and the car idle super smooth (1100 rpm cant get it any lower) and runs great whats the deal with not hooking up the advances?
|  04-09-2011, 11:30 AM | #5 |
				Rep Power: 20  |
			Alright I set my timing to 23* before top dead center on the Leading and 8* before top dead on the Trailing and at 5k RPM. I don't hook the vacuum up because I find it redundant.
|  04-09-2011, 06:31 PM | #6 |
				Rep Power: 18  |
			Check your gaskets and vacuum ports on carb sounds like a vacuum leak mine I can make it idle close to 600 rpms. Make sure the carb to intake gasket is good
|  04-09-2011, 10:15 PM | #7 |
				Rep Power: 16  |
			sprayed throtlle body cleaner (extremely flammable) while running no change in rpms, so i would say gaskets are good i can change timing and have it idle lower
|  04-09-2011, 11:51 PM | #8 |
				Rep Power: 20  |
			Any improvment?
|  04-10-2011, 01:56 PM | #9 |
				Rep Power: 16  |
			havent had time to mess with it yet, i will do it tomorrow and let u know
|  04-14-2011, 07:09 PM | #10 |
				Rep Power: 16  |
			did timing the way u said fc zach car started running hot and had a horrible low end no improvement to upper end, so i set it the way racing beat says too no problems runs great, just need a regulator now fuel pressure is fluctuating alot
|  04-14-2011, 10:21 PM | #11 |
				Rep Power: 20  |
			It sounds like you used the markings on the pulley, which are used to set timing at idle. However you did it, you got it to work now.
| Tags |
| 12a carb timing tuning |
