Old 05-20-2009, 12:57 PM   #31
My5ABaby
My5ABaby's Avatar
Some preliminary pictures. The first two pictures are with the lamp and LEDs being on a kitchen height table. The camera settings were the same between the two pictures. The LEDs are currently running with 47k Ohm resistors and I plan on changing them to 22k Ohm (meaning about 1/3 brighter). The LED picture has some glare but it's not too far from the actual brightness. It's painful to look directly at them in the dark. I test fit them through the housing and it dims them slightly and changes the throw a bit wider.
The third picture shows one of the first boards I made. I figured I might as well put up a picture since anyone who really wanted to do it could figure it out themselves. Might as well be nice...
My next pictures will try to be a direct comparison of the LEDs and regular reverse light actually in the housing.
Community Service Manual
RotorWiki
Old 06-21-2011, 02:02 PM   #32
fc3sfreak415
Wankel Works
fc3sfreak415's Avatar
fc3sfreak415 is on a distinguished road
BEAUTIFUL WORK!!!! ive always wanted to see someone do this
fc3sfreak415 is offline   Reply With Quote
Old 06-21-2011, 02:42 PM   #33
My5ABaby
My5ABaby's Avatar
Thanks
I've got 1 side of the reverse lights in currently but have been too lazy to do the other side (which doesn't matter too much since my reverse switch barely works). I voltage limited them to 12v and they aren't as bright as they could be. Given that they're on for such a short amount of time I think I'm just going to run them off the alternator voltage to brighten them up some.
RotorWiki
Old 06-22-2011, 10:34 PM   #34
88turboii
destroy, rebuild, repeat
88turboii's Avatar
have you thought about making a big pcb to mount all the leds and circuits to instead? or too expensive because of the size?
Old 06-23-2011, 08:40 AM   #35
My5ABaby
My5ABaby's Avatar
The way the tail lights are made there's dividers between each compartment so it would be basically impossible. I already had to grind down the plastic on the housing (the part closer to the car) about 3/4" to allow the PCBs to fit. It's actually a ton of work beyond just creating the PCBs. Once I learned how to wire/mount the LEDs, resistors, etc. to the PCB, those are fairly easy, just time consuming. The wiring, modifying the housings, etc. is also a huge pain. The whole project is probably about 70 hours of work, although if I knew what I was doing from the get-go it'd probably be more like 40.
RotorWiki
Old 03-20-2013, 01:09 PM   #36
casual_john
Dover White GXL
casual_john is on a distinguished road
I'm interested in just the third brake light. Or do you think having bulbs for the taillights, but LEDs for the third middle light would look dumb?
I believe that piece would be common among all FCs, both S4 and S5.
How much if I send you my core and you modify it? Plug and play style.
(FC guys are always on a budget, you know.)
casual_john is offline   Reply With Quote
Old 03-20-2013, 03:15 PM   #37
My5ABaby
My5ABaby's Avatar
I think it would not look good to have a mix, but I also don't have the option of making these for other people. Sorry.
RotorWiki
Old 04-13-2013, 07:51 PM   #38
I think I might be doing this now. Would you mind posting or PM'ing the stuff you got/where you got it from?
Old 04-13-2013, 09:40 PM   #39
My5ABaby
My5ABaby's Avatar
I'll see if I can find any of the info, but it's been so long I don't really remember much of it. I know I got the PWM boards and red LEDs from azdave on hidplanet.com.
RotorWiki
Old 04-13-2013, 09:47 PM   #40
Do you at least remember the cost of everything? I would imagine somewhere above $200?
Old 04-13-2013, 11:26 PM   #41
My5ABaby
My5ABaby's Avatar
Yes, quite a bit above $200. My guess would be somewhere around $400, if not quite a bit more. I used nearly 500 LEDs as I recall, which were something like $.30/ea. The PWMs were something like $30/ea. Part of the issue is having to order so much of some of the stuff like resistors. Minimum orders are like 100 of some that I only used 10 of.
RotorWiki
