Old 07-07-2011, 10:55 AM   #1
Aees
Aees is on a distinguished road
Aftermarket FPR
Is it possible to install an aftermarket fuel pressure regulator with the stock rails? If not, where can I buy new fuel rails for my S5 TII Vert?
Aees is offline   Reply With Quote
Old 07-11-2011, 06:25 PM   #2
NoDOHC
NoDOHC's Avatar
This completely depends on what rails you are running. If you have the S4 type with the threaded fitting in the end, replace the FPR with a banjo bolt and install an aftermarket one downstream of that. I think that all turbos had a threaded secondary fuel rail.
Old 08-29-2011, 12:50 PM   #3
Aees
Okay, mine doesnt have a threaded fitting in the end, so guess I need a S4 rail then. Are they the same except from the threaded fitting?
Old 08-29-2011, 01:40 PM   #4
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
I had my friend cut my S5 rails and weld on steel -6 AN weld adapters.
1. Walk through a row of 22", or larger, rims
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
EJayCe996 is offline   Reply With Quote
Old 08-29-2011, 09:11 PM   #5
My5ABaby
My5ABaby's Avatar
They're not the same, but you can use an S4 on an S5. You just need to get some washers to space it appropriately and probably some longer bolts to hold it on.
Community Service Manual
RotorWiki
