Old 02-11-2011, 12:07 PM   #136
RX-Heven
RX-Heven's Avatar
RX-Heven is on a distinguished road
Mind putting up a simple labeled diagram of your fuel system?
-Dave
20b RCR Superlite Coupe
91 Widebody Turbo Vert...RIP
RX-Heven is offline   Reply With Quote
Old 02-20-2011, 08:26 PM   #137
To_Slow
I will try to explain the best I can.
2 feeds 1 return
1 -8 AN feed from the prime pump ( in tank 044) to the FPR with a non return check valve after the pump.
1 -10 feed to the mechanical fuel pump with a check valve before the pump.
1 -10 return from the FPR
The prime pump is on a ON OFF switch, once the car is started there is enough vacuum /gas draw on the mechanical pump to shut off the prime pump. At the same time if the belt on the mechanical pump breaks I will have some what fuel pressure from the prime pump to make it home/off the track/ in to the trailer.
I hope it makes sense. if not I will be more than happy to respond to any ?? you / someone ales might have.
Thanks
My link
Old 02-25-2011, 08:48 PM   #138
[200[
[200[ is on a distinguished road
Hey there,
Just a quick one about the water coolant inlet neck on the front iron. Are you able to tell me who made it? What dash size are the fittings attached to it?
Love the project, will be keeping my eye on it!
[200[ is offline   Reply With Quote
Old 02-26-2011, 01:03 PM   #139
To_Slow
http://www.meziere.com/ps-1300-1266-wp91.aspx -16
And the mop stick from walmart priceless ...
My link
Old 02-27-2011, 02:52 PM   #140
[200[
I thought it would have been a Meziere product, I had a look on their website before asking and couldn't find jack. Did you have the piece of aluminium holding the water temperature sensors fabricated?
Old 02-27-2011, 04:53 PM   #141
To_Slow
Yes its a water jet item...
Thanks
My link
Old 03-17-2011, 12:49 PM   #142
To_Slow
Just a sneak peak.....
Uploaded with ImageShack.us
My link
Old 12-22-2011, 10:07 PM   #143
Prometheus
Prometheus's Avatar
Prometheus is on a distinguished road
Any chance of snapping a picture of the engine/ steering rack proximity?
Prometheus is offline   Reply With Quote
Old 12-23-2011, 12:20 PM   #144
knonfs
knonfs is on a distinguished road
My understanding is that the project was never completed, and parted out.
knonfs is offline   Reply With Quote
Old 12-23-2011, 09:38 PM   #145
To_Slow
WoW.. That's sad.. But i got dibs on the engine...
My link
Old 12-24-2011, 12:26 AM   #146
Brent
Sua Sponte
Brent's Avatar
As I said in the other thread, looks awesome Chip!
Old 12-24-2011, 01:02 AM   #147
To_Slow
Thanks Brent, i love forum roomers... ....
My link
Old 12-27-2011, 09:26 AM   #148
knonfs
Sorry, I think I confused your build up with somebody elses
Old 01-21-2012, 10:39 PM   #149
To_Slow
Small update,
Dressing up the turbo GT45rbb with some space age material ... Carbon Fiber .....JK .......
At the same time, i'm having a company make me a custom mesh stainless steel 3 layer disk type filter 25 micron, for my turbo. It will be wedged be twin the carbon fiber cone and the turbo inlet flange. That will serve as my turbo inlet filter. Reason... I'm unable to run a standard K&N type filter do to tight space.
Also this little nifty remote thermostat housing -16 feed /-16 out and a 1/4 NPT bypass port with a 160 thermo inside ...
My link
Old 01-24-2012, 10:57 PM   #150
prrex4ever
prrex4ever's Avatar
That carbon fiber intake on the turbo looks GREAT!
