Old 04-24-2008, 07:11 PM   #1
Oil pan leak
I can see that my oil pan is leaking on my '04 8. It only has 36K on it and started leaking back around 35k. I know FDs had this problem, but the 8? Is this common? I'm going to fix it w/ some new sealant and will probably stud the pan too just to be sure its secure and sealed.
I wish somebody made a brace for the renesis...
Old 04-24-2008, 08:04 PM   #2
fikren
fikren's Avatar
fikren is on a distinguished road
I'd say its going to be a common issue with the 8 just like it is with the 7. Other than some differences in exhaust ports and intake ports its still essentially the same block and I doubt the pan has change that much if any. You might be able to bug garfinkle see if he has any plans of doing a brace for the 8 or check and see if anyone has one of his fd braces sitting around for a test fit to see if it would possibly work.
What are they using for the gasket material on the 8 any idea?
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
Old 04-25-2008, 12:07 PM   #3
I took apart a renesis a few months ago...
No gasket on the pan, just Mazda Grey sealant... which is basically permaseal grey.
Mazda wants $49 a tube for their brand - permaseal is $9 a tube, lol... it might take 2 tubes - but still $18 vs $49...
Old 05-22-2008, 08:44 PM   #4
Follow up on this issue. I discovered the car also had a trans leak - and being that it was under warranty, I went ahead and had the stealership fix it.
Oil pan was in fact leaking - they resealed it.
The transmission's main housing gasket was leaking - they replaced it.
I also had a new key cut and programmed so I'm good to go now... Just wanted to document this in case other 8 owners start experiencing the same thing.
Old 05-23-2008, 10:01 AM   #5
Mine was leaking a little when i bought it..
I actually talked to Garfinkle about this but when I posted on RX8 club and GA RX8 club, no one was interested..
Garfinkle wants at least 20 people to start a production.
I have a spare one to send it to Gar and he's interested pending interest..
Old 05-23-2008, 11:53 AM   #6
fikren
fikren's Avatar
how different is the 8's oil pan vs the fd's oil pan? I've never looked at the differences on them.
93 bb rx7
Proton Fushmounts
Sato Rearsets
Old 05-23-2008, 03:07 PM   #7
I havent had one side-by-side, but the 8's pan seems to have a much more rigid rim and is baffled differently. Its also a lot shallower from what I can tell...
As for the actual bolt pattern though, I'd be curious myself and see. I dont even have an extra 13B oil pan laying around from any gen to compare.. Phil bought my other 8 pan, lol.
Old 05-23-2008, 03:08 PM   #8
Phil - Tell him I'm down for one if they make it.. is there a GI thread somewhere?
Old 05-24-2008, 10:25 PM   #9
Sounds good.. If you could pass on the word and start a Group buy interest thread, that would be awesome! I could take some 8 vs FD pan difference and the brace Gar made for the FD.
I'll try to do that tomorrow
