Old 05-11-2013, 01:31 PM   #361
Tegheim
Tegheim is on a distinguished road
Have worked alot on these rotors this week. Totally 32 times on 4 rotors in the machine.
Tegheim is offline   Reply With Quote
Old 05-30-2013, 09:36 AM   #362
Tegheim
I bought a bunch of new rotors. How do I comfirm that they are 9.7:1-compression?
I have weight them, but all the newer rotors have the same weight. The 28cc in the comb-chamber are kind of tricky to check, or?
Old 07-06-2013, 01:28 PM   #363
Monkman33
Still Building my FD
Your build up is awe-inspiring!
Uh.... hi.
Old 07-12-2013, 08:07 AM   #364
Tegheim
Today I get to play with the big boys :-)
http://www.build-threads.com/category/build-threads/
Old 07-16-2013, 08:20 PM   #365
theorie
VRR PSSH
theorie's Avatar
theorie is on a distinguished road
This is one of the best build threads ever. Thank you for sharing this.
1993 SSM, 20B (D449), SINGLE-TURBO, DIY-BUILD IN THE WORKS... |Build Thread|
1993 BB, 13B, SINGLE-TURBO, DAILY DRIVER |Build Thread|
MY FACEBOOK PROFILE // BLACK LABEL ENGINEERING // ADVANCED RACE TECH // IR PERFORMANCE // THE BOOST LAB //
[url=rotaryaddicts.com]
theorie is offline   Reply With Quote
Old 08-27-2013, 12:52 PM   #366
Tegheim
Havn't done much lately, but have done some with the steering, the wattlink and finally some on the intermediate-plates.
This was a LEGO i designed
And this is how that goes in the car.
Here the intermediate-plate is prepared for the bearing
Old 08-27-2013, 02:32 PM   #367
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Just staring at that front end.
Nice work.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 09-25-2013, 09:19 PM   #368
the spyder
the spyder is on a distinguished road
Amazing build. I need access to some of those tools! Just the raw material for the engine would break my budget, haha. Can't wait to hear the startup video.
the spyder is offline   Reply With Quote
Old 09-25-2013, 09:30 PM   #369
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
take a caliper and a flat piece of metal, mic the metal and zero out the gauge. lay the strip over the pocket and measure the depth of just the pocket and it should be very close to 10.85mm in depth and have a machined relief(the deeper the pocket is, obviously the lower the compression is). this is the measured depth for the 9.7:1 rotors.
turbo rotors also have a T stamp embossed into the oil relief vein area facing the center iron, n/a rotors have no T stamp, just a I and II for front and rear(which accompany the T on turbo rotors).
that said, the quickest and easiest method is just check the oil galley in the rotor for the T stamp(or lack thereof in this case) and make sure the rotor has a machined pocket for the series 5.
if you somehow managed to get renesis rotors they're a little less conspicuous with their scallops and thick side seal lands.
http://rotaryevolution.net
Old 09-28-2013, 12:20 AM   #370
Anoesis
Anoesis's Avatar
Anoesis is on a distinguished road
Neat!
Anoesis is offline   Reply With Quote
Old 11-08-2013, 02:53 PM   #371
Tegheim
Have lately spent some time with the porting of the engine. Most in SolidWorks, but also in reality.
Thought I run with V-band instead of what is in the renderings. However, I must turning one half of the V-band myself, and it seems difficult to find the measure of it.
If anyone has seen it, or know how they should look like, I am receptive :-) Happy to metric! The tubes I intend to use is 50x2, ie 46mm internally.
Old 11-08-2013, 05:14 PM   #372
jahjahsqc
jahjahsqc is on a distinguished road
An engineering marvel! very impressive!
jahjahsqc is offline   Reply With Quote
Old 11-09-2013, 12:59 PM   #373
Tegheim
Continued today with the trash-housing.
Did a test sleeve in the cnc-lathe. I am very satisfied with this. Have minor improvements to do with the real ones later.
Old 11-09-2013, 05:36 PM   #374
diabolical1
I have radioactive semen
agreed ... and yet still i still find the words so bloody inadequate.
Old 11-23-2013, 04:17 PM   #375
Tegheim
I have been thinking about the intake. I would want to have tapered runners, but because "someone" decided to lower the entire body over the frame, there isn't much space above the engine.
This means that I have to make a turn on 156.5grd pretty tight around the engine and land on the block. The options are to cast runners in plastic, carbon fiber or aluminum perhaps?
Today I continued to mod my intermediate irons for more bearings.
First I layed a the intermediate and clamped it. Then either front or rear iron onto to indicate the centrum.
Machined two new very tight dowels. As tight as possible.
Even then you can move the plate 0.015mm in both directions. I alinged in the middle of the play.
