Old 07-18-2013, 09:45 AM   #1
Cleaning out oil cooler after bearing failure?
are there methods for cleaning out an oil cooler after having bearing failure? or perhaps is it a professional job? Id rather reuse this one, than have to buy a new one.
Old 07-18-2013, 10:42 AM   #2
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Bawbers and I were just talking about this over the weekend... apparently the old school trick was to soak/flush them with kerosene then flush 'em out with oil.
We were talking about it because the oil temp in my bimmer is too high, figure there is buildup in my oil lines or oil cooler..
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 07-18-2013, 11:01 AM   #3
i could probably funnel it in there and slosh it around. repeat a few times til it comes out clear.
Old 07-18-2013, 11:08 AM   #4
JL1RX7
If your cheap use water then a dose or two of Kerosene and oil.
Old 07-18-2013, 11:12 AM   #5
how did you know. Well, that would get more pressure going through...
Old 07-18-2013, 11:19 AM   #6
JL1RX7
Fluid is fluid. Normally you would want to flush your coolers with what your normal fluid is. Pressurize the system and flush away. Have to have some sort of filters to catch the bad stuff. Now the kerosene will cut the oil sludge that is in the cooler and flush it out when you dump it. All those microscopic pieces are the hard ones to get but it will work.
Water will do some of this. Not as well and will mostly float over the oil sludge that is built up inside. But it will get the big chunks out and then on to the other stuff.
I flushed many a hyd system on jets and god knows how many times on the radar cooling systems. There was a little easier since we had GSE to support the flush and fill.
Old 07-18-2013, 11:28 AM   #7
yea i have a bucket, a hose, and a 5 gallon gas can. maybe a funnel
Old 07-18-2013, 11:30 AM   #8
JL1RX7
Trying to offer a good time?
Old 07-18-2013, 11:31 AM   #9
mmmmmaybe
Old 07-18-2013, 11:32 AM   #10
JL1RX7
crap I forgot this isn't the lounge.... Sorry.
Old 07-18-2013, 11:58 AM   #11
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Originally Posted by jl1rx7 View Post
crap i forgot this isn't the lounge.... Sorry.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 07-18-2013, 02:30 PM   #12
FC Zach
FC Zach's Avatar
I used a cheap universal fuel pump and a large pan filled with a few quarts of kerosene to circulate kerosene through the cooler till the fluid coming out the other end was clear. Seemed to work well and I didn't waste much kerosene either.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 07-18-2013, 04:23 PM   #13
I've used mineral spirits before as well, flush it good and call it a day. I would do an oil change within 500 miles after running everything though, just as added (cheap) insurance...
Old 07-18-2013, 04:40 PM   #14
FC Zach
FC Zach's Avatar
^ Good tip, I did the same. I checked my filter, cutting it open and found brass in the filter element even after flushing the crap out of the cooler. It was that way for a couple oil changes, gradually cleaner each change. I guess the flushing only gets most of the debris.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 07-18-2013, 05:23 PM   #15
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Where did you get the pump you used Zach? I had complete bearing failure due to (unknowingly) dumping all my oil while driving down the highway... I'm thinking that a flush like what you did would be just the ticket for me!
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
