Old 07-25-2013, 04:46 AM   #76
Stredrotor
Stredrotor is on a distinguished road
Originally Posted by Whizbang View Post
this might sound silly, but the TKO does not share the same pattern as a T-5 tremec correct?
Not sure Whizbang
RX4 coupe 20B conversion http://www.rotarycarclub.com/rotary_...ead.php?t=9884
Stredrotor is offline   Reply With Quote
Old 07-25-2013, 09:11 AM   #77
Originally Posted by Stredrotor View Post
Not sure Whizbang
I have T-5s laying around I would love to stick to a rotary.
Old 08-25-2013, 05:08 AM   #78
Stredrotor
Just a small update.
Got the tail shaft done by the guys at Jayben. 3 inch, one piece.
Old 08-26-2013, 10:15 AM   #79
RedR1
Brokeback Power!
RedR1's Avatar
RedR1 will become famous soon enough
i am loving this project
RedR1 is offline   Reply With Quote
Old 08-31-2013, 04:52 AM   #80
Stredrotor
Started work on the sump as the custom one that come with the motor won't fit. I had the flange cut then started working on how much room I have.
I removed the old front engine mount cross member as I need a bit more clearance.
Then I mocked up the lower half in cardboard.
Next to the old custom sump.
After that I modelled it up in Inventor.
Even welded it!
Should give me a bit over 5 litres capacity.
Now I just need get the lower half cut.
Old 09-02-2013, 04:12 AM   #81
Stredrotor
Spent a bit of time in the shed last night an made a tail-shaft loop.
I used the factory studs for the old two piece tail-shaft.
Old 10-23-2013, 03:59 AM   #82
Stredrotor
Had a little bit more progress.
I got back the laser cut parts for the sump and tack them together for a trial fit up.
Good clearance on the crossmember.
But after checking clearance on the oil pickup I knew I had a problem.
This is a 13B turbo pickup.
Started to design a lower profile pickup.
The sump will have to be modified.
And even then I will have to lower the swaybar. Might have a look at some of those anti-dive spacers.
Old 11-14-2013, 08:11 PM   #83
Stredrotor
Made the sump pickup today!
Old 11-14-2013, 10:45 PM   #84
bacteria
bacteria's Avatar
bacteria is on a distinguished road
Awsome project!
bacteria is offline   Reply With Quote
Old 11-15-2013, 07:50 AM   #85
banzaitoyota
banzaitoyota is on a distinguished road
Looks good
My deuce
banzaitoyota is offline   Reply With Quote
Old 11-22-2013, 08:27 PM   #86
Stredrotor
Parts for my sump are made ready for welding!
The flange is screwed to a piece of 8mm steel plate to help with distortion, here with the sump pickup in place.
Here with the sump base and pickup cover plates.
Hopefully organising the welding next week as I don't have an AC TIG to weld alloy.
20b, mazda rx-4
