Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Re-Speed
Re-Speed www.re-speed.com (GA) Custom rotary parts, specializing in 85-older
Old 06-03-2008, 08:48 PM   #1
one320fc
one Apex @ a time
one320fc's Avatar
one320fc is on a distinguished road
Question about your brake kit
So is it possible to use your front brake kit with S4 4 lug hubs and T2 4 pot calipers? I would like to stay 4 lug if possible and have the bigger brakes. Thanks again for the great things your doing for the FB community!!!
one320fc is offline   Reply With Quote
Old 06-09-2008, 09:59 AM   #2
bwaits
Talk - Action = Nothing
bwaits is on a distinguished road
Sure thing!
Use a 4 lug FC hub, our kit and 4 piston calipers. Drill a 5 lug turbo rotor to 4 lug pattern.
When drilling a 5 lug to 5 lug you will pick up on one of the 5 lug holes and then drill 3 new holes on the 4 lug pattern.
For the rear you need GSL-SE axles and to drill the rotors the same way.
-billy
bwaits is offline   Reply With Quote
Old 08-27-2008, 12:42 PM   #3
fire85gslse
fire85gslse's Avatar
sweet idea for the GSL-SE!
Thanks billy for your great products for the 1st gens.
Old 09-08-2008, 01:58 PM   #4
i have a continued question.
I bought the front brake kit as of 10 minutes ago.
While i have the assembly to run 5 lug in the front, can stock rx7 15" wheels work? I am aware that the 14" wheels would only work with the single piston 4 lug stuff (since it came with a 14" wheel) but i would rather have the 4 piston calipers and just deal with having a different wheel up front for now.
Old 09-09-2008, 04:36 PM   #5
bwaits
15" is the minimum on diameter. The backspace of the wheel will need to be 4.5".
-billy
Old 09-09-2008, 05:17 PM   #6
so would a stock rx7 wheel work?
Old 09-09-2008, 08:52 PM   #7
Rogue_Wulff
Non Member
I believe you would need something else than stock FC wheels. I read somewhere that the FC 5 lug upgrade on an FB requires around +15mm offset wheels.
Old 09-10-2008, 11:29 AM   #8
another question, since i am using GSLSE spindles, the assembly PDF says the 1/8" spacer is for non-se cars, so to make sure, that means i do not use the spacer when installing the kit, and just bolt the mount plate to the hub, correct?
Old 09-10-2008, 04:38 PM   #9
bwaits
Yes, FC wheels need a 1" spacer from what I hear.
THat part of the assembly manual is a mistake. The one that ships with the kits will have that marked out. That is only for the rear kits. A bit of copy/paste mess up.
So, you WILL use the spacers.
-billy
Old 09-12-2008, 07:02 AM   #10
so i did some number crunching.
i want to use the BBS Vert wheels. Now they are supposedly a 15"x6" with a +38 offset
So that would mean "0" offset would be at a 3" backspace. The difference is then 38mm which divided by 25mm (~1 inch) i would have 1.52 inches.
So that would give me a total of about 4.52 inches of backspacing on a vert wheel
so they "should" work. yay! Now just waiting around for the kit to arrive.
Old 09-12-2008, 03:17 PM   #11
Rogue_Wulff
Non Member
Just remember that with 1" spacers, you really should use longer studs. The stock studs will likely be too short to allow the wheels to be torqued down properly. Anything less than 7 full turns on the lugnuts, is a disaster waiting to happen.
Old 09-19-2008, 08:14 AM   #12
so after checking they are 6.5" wheels so i will rerun some numbers then.
15"x6.5" with a +38 offset.
so "0" offset would be about 3.25" backspace. So in total, 3.25" plus 1.52" inch would give 4.77" backspacing. That is a bit over what will easily fit, so a space will be needed, but not TOO bad of a size. Ill probably run a slightly stretched tire on it with something like a 45 sidewall. Ill see what clears from there.
Old 03-12-2009, 04:29 PM   #13
hoping to get the kit installed this weekend!
Also is the PDF now updated and correct? I have SE front spindles, so does that mean i will have to use the spacers correct?
Old 03-12-2009, 05:01 PM   #14
bwaits
Gold spacers are always used on the front kit. No matter the spindles. Ignore that part in the front manual.
-billy
