Old 11-14-2008, 05:15 PM   #1
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
rear tire camber is off
The passengers side rear tire is leaning inward, causing my tire to wear unevenly. I know that the strut is blown, but am not sure if that would cause this problem. I have inspected the suspension quite well and I don't see anything out of order (compared to the other side) and everything feels pretty tight for a 21 year old car. Thanks for and help or advice.
Old 11-14-2008, 05:38 PM   #2
how's your lateral link? Have you hit anything recently? No doughnuts into a curb or anything like that?
Old 11-14-2008, 07:03 PM   #3
jgrewe
jgrewe is on a distinguished road
There are a lot of rubber bushings spread all over the suspension that can cause this. Since its on one side only, check everything for movement and look again for anything bent anywhere.
New rat from the sinking ship.
jgrewe is offline   Reply With Quote
Old 11-14-2008, 08:00 PM   #4
Rotary_Rocket_87
i know that nothing is bent but i the same problem with the front but there is less complication in the front suspension. All i did was replace the struts and it fixed the camber problem, but the rear is so much more complicated. I know that i haven't hit anything and it has been like this for a while now. I was hoping that someone else has had the same problem and could give me some advice.
Old 11-16-2008, 07:17 PM   #5
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
There is no camber adjustment for the rear. If only one wheel is having a problem. I'd suspect the strut or spring. Since you already know that the strut is blown. I'd start there, it's relatively cheap and easy to replace provided you're mechanically inclined. I feel where you're coming from though... wouldn't want to put on a new set of tires to find out the hard way that it's not fixed. Alternatively, you could put on a used tire and see how that wears or you could pay for a lifetime alignment somewhere. They will tell you if there's a problem so you will have ample time to fix it before shredding your new tires and they will re-align it for free once you have it fixed. I should warn you, if you do replace the strut yourself... ALL those little parts are there for a reason. Go ahead and leave out the one that doesn't look like it does anything and you'll see exactly what I mean.
1988 GXL
Old 11-16-2008, 07:51 PM   #6
N3philum
Unreliable Like a Rotary
N3philum is on a distinguished road
can you post a pic? i had a similar problem on my old FC.
N3philum is offline   Reply With Quote
