Old 02-18-2009, 11:50 PM   #1
Nopis1O
Nopis1O's Avatar
Nopis1O is on a distinguished road
Modified gauge cluster
Is there anyway a tach could be off by a couple thousand rpm's? Its an aftermarket tach and i think it is about 2000rpm's above what that actual engine is reving at. is this possible? if it is, is there anyway to check and fix the problem?
thanks
1988 Fc Vert. Super Stock
1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
Nopis1O is offline   Reply With Quote
Old 02-19-2009, 12:49 AM   #2
well i wouldnt put it passed it. Best thing to do though is just hook up another tach to the signal wire and compare.
Old 02-19-2009, 08:45 AM   #3
Ender
rotors excite me
Ender's Avatar
Yeah, anything's possible. See if you can't look up info/instructions for that particular tach and then find out how to set it for 4/6/8 cylinders, it may be set wrong. I don't remember which setting is appropriate for stock FC timing, but I'm pretty sure one of them is (I think it's 4cyl).
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 02-19-2009, 02:09 PM   #4
Caim
Caim's Avatar
Caim is on a distinguished road
Easy way to tell is if it is at 0 when the car is off. If it is then make sure that it is connected right. Go from there.
Caim is offline   Reply With Quote
Old 02-19-2009, 02:21 PM   #5
Roen
Evil Club Mod
Roen's Avatar
FC's should be set at 4 cyl for tachs.
Old 02-19-2009, 05:57 PM   #6
Flooder
Flooder's Avatar
Flooder is on a distinguished road
Are you getting the tach signal from the trailing coil? If not that could be why.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 02-19-2009, 07:12 PM   #7
Nopis1O
Nopis1O's Avatar
I think im going to reset it to make sure its on 4cyl cuz im almost poss. its on the trailing coil but i will check that too. Thanks Guys!!
Old 02-19-2009, 07:14 PM   #8
Flooder
Flooder's Avatar
Theres also a check connector that you can connect it to to receive a tach signal. It should be on the drivers side of the engine bay, and its a green plug. Look into that as well.
AZRX7.COM
Red 1990 GXL(SOLD)
Old 02-19-2009, 09:38 PM   #9
this is that carbed N/A btw, the stock coils have been replaced with MSD super blasters...
...or whatever.
Old 02-20-2009, 02:55 AM   #10
Nopis1O
Nopis1O's Avatar
yea thanks max. did you think that idle sounded like it was at three k?
Old 02-20-2009, 04:48 AM   #11
Plugged into the STOCK leading coil check connector - "4 cylinder".
Plugged into the STOCK trailing coil check connector - "8 cylinder".
If you're using a distributor that uses one coil for leading and one coil for trailing, it should be "4 cylinder".
Old 02-20-2009, 07:45 PM   #12
well, i dont know what a 3k idle sounds like with exhaust, but my car was pretty loud when I first got it running.
It only had an open header back then, and was idling roughly at around 2,800 rpm. I had a bad TPS and aparently a vaccum leak.
