2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
corksport turboback, fmic kit, BNR turbo, t4 manifold, 550/1680's, stock stuff, more!
As you can see i have a TON of parts i would like to get rid of...Please PM me for fastest response. If you need something that isn't listed let me know, i might have it.
BNR Stage 2 (I believe) S5 turbo -$575 shipped. No shaft play. Polished compressor housing, ported wastegate. Comes with manifold, SS oil feed and return lines (-4AN/-8AN). Also comes with all gaskets, coolant lines, banjo bolts and crush washers. Looking to sell as a package. Corksport Power Series turboback exhaust - $450 picked up, $500+shipping. Used for ~3000 miles. No rust or damage. Will come with all hardware, gaskets, and hangers. This is the full turbo back exhaust…not the catback. Retails new for $630. Custom fmic kit - $450. Comes with intake elbow, all couplers, clamps, 2.5” aluminum piping w/ genuine HKS bov. (2) recently rebuilt 550cc injectors - $75 (2) new marren 1680cc injectors - $150 S5 t2 UIM/LIM/TB/TPS (block off plates included) - $150 unknown SS t4 turbo manifold - $75 s5 alt w/ dual pulley - $75 SS clutch line - $20 T2 clutch slave cylinder - $20 S5 T2 fuel rails w/ new fuel line and fuel filter - $50 t2 throttle cable - $35 oil cooler - $40 hks intake - $40 k&n intake - $40 S5 Turbo TPS w/ connector - $50 shipped GM Air intake temp sensor w/ NEW connector - $25 shipped s4 t2 battery/starter harness - $50new fc thermoswitch/coolant sensor w/ plug - $20 jspec top mount - $25 coolant overflow bottle - $10 stock rad hoses - $8 flywheel socket (1" drive) - $10 n319 jspec s4 t2 ecu - $20 variable resistor - $8 radiator brackets (look new) - $25 cold start bottle - $15 charcoal cannister - $10 (2) s5 round injector plugs - $8 PCV (purge control valve) - $7 OMP vacuum spider - $7 s4 t2 n326 atmospheric pressure sensor - $8 s5 fuel pump resistor/relay - $15 s4 t2 fuel pump sending unit - $25 s4 t2 jdm lim - $25 s4 t2 jdm uim - $20 s4 t2 usdm lim - $20 s4 t2 turbo to exhaust mani gasket - $8 s4 t2 jdm bac - $15 strut top covers - $8 s4 t2 cruise control computer - $10 s4 t2 power steering computer - $10 s5 NA engine harness (great shape, missing rats nest plugs, have a spare harness with those connectors that i can include) - $50 s5 TPS - $35 s4 t2 thermostat neck - $15 plastic piece between coolant filler neck and thermostat neck (w/ overflow nipple & cap) - $25 plastic piece between coolant filler neck and thermostat neck (w/o overflow nipple & cap) - $25 long oil cooler line - $15 motor mounts and brackets $40
87 T2 90 T2 'Vert ![]() Last edited by 87 t-66; 02-24-2009 at 05:21 PM. |
Clean S4 Nutswinger
Any pics of the T4 manifold? Divided or undivided?
-Ted -1986 Mazda RX7 Sport [DD/beater]: engine finally let go at 205k. parts car status. -1986 Mazda RX7 base [resto-mod project]: S5 n/a swap in progress. ![]() |
#3 | |
Rep Power: 21 ![]() |
pics and details of the FMIC kit.....I was about to get an ebay kit (3" core) for $400 (shipped) but if you can match that I'd rather give YOU the money...
#4 | |
undivided...ill snap a pic of it tonight and post it.
87 T2 90 T2 'Vert ![]() |
#6 | |
PM received...hit me up.
Bookmarks |
