Old 02-21-2009, 07:09 PM   #1
proz07
Needing a new tow rig.
proz07's Avatar
Clutch pedal mount, is this right?
Could anybody check thier FD and let me know if this is anywhere near correct. I have a hard time believing it if it is? im going to check the FSM but if anyone can check thiers for me that would help too.
Old 02-21-2009, 07:25 PM   #2
proz07
proz07's Avatar
well the FSM dosent show anything in that relation so im relying on you guys dont let me down!!
z
Old 02-21-2009, 07:34 PM   #3
David Jerome
David Jerome's Avatar
I dont recall the big washer thing but it can only really line up one way
David Jerome
Old 02-21-2009, 08:55 PM   #4
proz07
proz07's Avatar
ok so i found a pic of what my trashed FD had. As you can see the top is mounted correctly and so is the bottom at the fire wall. now i took mine out of my current FD and tried to line it up with this stripped FD shell that as you can see had a pedal mounted correctly and it will not mount correctly in this one either???? WTF it dosent look bent or anything so anybody got any ideas???
z
OK so i took some measurements and obviously the pedal is too short but WHY????? From to the firewall to the top mount stud is around 9.5" but my pedal is about 8.X" take look at these
and heres the clutch pedal in question.
Now the only thing i can think is the top bracket was out of alignment when spot welded and some how made it through into the car????? WTF so it looks like to fix it i will have to drill out the spot welds realign it at the correct length and then tig it back together.
another thing that i should state is the only difference between these two cars im testing this off of is the black one is a 94 and the montego blue is a 93.
z
Old 02-21-2009, 09:54 PM   #5
dinosaur
Member
dinosaur's Avatar
dinosaur is on a distinguished road
differences between model years, maybe.
93 VR RX7
09 Mini Cooper
75 Cosworth Vega
dinosaur is offline   Reply With Quote
Old 02-21-2009, 10:06 PM   #6
ObliqueFD
ObliqueFD's Avatar
ObliqueFD is on a distinguished road
The parts numbers are the same in the '93 and '94 parts fiche. In this picture, it looks like there is a hole behind the stud. Could you move the stud back to the hole behind it?
'93 SSM RX-7
'93 BB RX-7
'04 BB RX-8
ObliqueFD is offline   Reply With Quote
Old 02-21-2009, 10:34 PM   #7
proz07
proz07's Avatar
there is a hole there but its offset and only goes through the first layer of sheet metal and is offset by about an inch if i remember right. that could be an option but id rather cut and reweld the clutch bracket correctly as you can see in the pic the top mount point isnt even flush its angled upwards.
hey if anyone with a 94+ could take a picture of theres we could compare but by the measurments between a 93 and a 94 they are the same.
z
Old 04-12-2009, 06:04 PM   #8
proz07
proz07's Avatar
Fixed!! not pretty but fixed. i had to drill out the spot welds holding the bracket in place, reposition it and weld it back together. i also had to redrill holes and make holders for the spring retainers so it keeps the same spring pressure and pedal feel.
crap welds
spring tabs
z
Old 04-12-2009, 08:22 PM   #9
Signal 2
Viable Fossil
Signal 2's Avatar
Can't see the welds, who cares....looks like they're strong enough. If it works, good to ya.
Jim
VR R1 FD
Old 04-13-2009, 10:58 AM   #10
REVIT93RX7
REVIT
REVIT93RX7 is on a distinguished road
clutch Pedal
This is interesting. Mine is all apart so I will check mine and see what the length is. Although mine is a 93 as well.
REVIT93RX7 is offline   Reply With Quote
Old 04-16-2009, 05:50 AM   #11
REVIT93RX7
REVIT
Clutch Pedal
Checked the length of my pedal and it is indeed longer than 9 inches. The end closest to the driver meets the noise/shield material and does not have that big washer.
Old 04-16-2009, 04:42 PM   #12
proz07
proz07's Avatar
well kinda makes ya wonder dont it even has the FD01 code and everything wonder what a fc clutch pedal looks like? or some typr of explanation as to why there is this piece of s*** pedal in my car from the factory? But i have no way of know if it came that way or not. oh well fixed now.
z
