Old 04-18-2009, 11:03 PM   #1
P71
P71's Avatar
Angry Clutch problems / dilemma
So I installed a new Zoom MU-Series OEM clutch in the RX-7 last August. It's been autocrossing a bunch but only drag raced for 5 or 6 passes. It has maybe 4,000 miles on it total. Tonight the clutch pedal wouldn't release at the strip so I coasted and by the return road it was fine again. However now the clutch chatters like crazy on a dead-stop start, but doesn't make any noise once moving. It drove the 50 miles home A-OK and goes around the block stop/starting just fine (except the noises). It also smells faintly of burning clutch.
I called Summit (who I bought it from) who informed me they only have a 90-day warranty. Suck! Should I pull it and see what happened or??? I've broken plenty of clutches and it honestly feels like it literally just fell apart (shoddy materials/workmanship). I know it's seen "hard use" being in a sports car and autocrossed, but it still shouldn't just fall apart.
Any ideas? Suggestions for a better replacement?
Freaking autocross tomorrow too!
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
Old 04-19-2009, 12:02 AM   #2
josh18_2k
thats hella gay
i say pull the clutch asap and have a looksie. you should be just fine with a Luk or whatever. thats what i'm rockin
Old 04-19-2009, 06:20 AM   #3
Boostmaniac
almost sounds like you have some bent forks on your pressure plate.
Old 04-19-2009, 07:15 AM   #4
P71
P71's Avatar
It's so crappy Josh! I was seriously looking forward to rocking the 7 today and kicking some Boxter butt. I'm still thinking of taking the cop car...
Michael Pinto
Vote for the ROTM!
Old 04-21-2009, 11:29 PM   #5
had a similar issue with the throw out bearing being FUBAR
Old 07-20-2009, 07:34 AM   #6
orion84gsl
Wow, I know this thread is getting up there in age, but this is EXACTLY what just happened to my 4 month old stock replacement. I went to an autocross yesterday and on my last run I went to downshift into first and the pedal just sat on the floor. Brought the car to a stop and stomped the pedal a couple times and it popped back up. Clutch grinds on take off and stinks like crazy but she shifts and drives fine once rolling. I'm glad I found this thread because the grind only on takeoff had me concerned it wasn't the clutch disc and I don't have time to drop the trans and find out it's something else.
Old 07-21-2009, 07:47 PM   #7
orion84gsl
Well just finished changing out my clutch with an ACT 6-puck and the stocker came out just like yours, in two pieces. The flywheel side had seperated from the disc, and was also cracked in two places. Hopefully the ACT will hold up better.
