Old 08-26-2009, 11:18 PM   #1
dudemaaan
dudemaaan's Avatar
Tip:Calculate new injector flow based on pressure increase
So you know an injector flows 550cc at 40 psi, now you want to know how much it flows at 50 or 60 psi. This simple formula will allow you to calculate it quickly. Works for aux injection systems, fuel injection systems, hell it will even work on your sewer system if you really cared to know.
SQRT(New Pressure / Old Pressure) X Old Flow Rate= New Flow
We'll use the above 550cc @ 40psi base pressure as an example.
example: New pressure = 50psi, old pressure = 40 psi, old flow rate = 550cc
So hit square root on your calculator, enter 50 divided by 40, then multiply times 550= 687cc <---- this is your new flow
Old 08-28-2009, 09:55 PM   #2
Garfinkles Motor Works
Good info ,thanks
Old 09-06-2009, 10:55 AM   #3
I need to see a fuel calculator ,what size injector ,injectors, for x amount of power .Do you have one ?
Old 09-06-2009, 01:09 PM   #4
dudemaaan
dudemaaan's Avatar
yeah this is the one I like to use.
http://www.maxcooper.com/rx7/how-to/...tem/calcs.html
Old 09-06-2009, 09:10 PM   #5
Thank you for your time .
Old 09-07-2009, 05:39 PM   #6
prrex4ever
prrex4ever's Avatar
Great info, thanks. I will keep this for future use.
Old 09-08-2009, 02:42 PM   #7
dudemaaan
dudemaaan's Avatar
No problem. I use the formula all the time
Here is another great link, shows flow graphs for a lot of popular pumps both stock and after-market.
http://www.stealth316.com/2-fuelpumpguide.htm
Here is one of many graphs as an example.
Old 09-08-2009, 07:11 PM   #8
05rex8
Turbo 8
05rex8's Avatar
05rex8 is on a distinguished road
found this site to be really helpful
http://kgparts.com/index.php?page=fuel-calc
05rex8 is offline   Reply With Quote
Old 09-14-2009, 01:00 PM   #9
TimeMachine
TimeMachine's Avatar
TimeMachine is on a distinguished road
I occasionally use this one as well:
http://www.rceng.com/technical.aspx#WORKSHEET
1995 Mazda RX-7
2006 Infiniti FX35
TimeMachine is offline   Reply With Quote
