Old 09-22-2009, 10:01 PM   #61
Jeezus
Jeezus is on a distinguished road
Originally Posted by BigIslandSevens View Post
I installed all the bushings tonight. I used the arm press My hands are sore as hell.
Pics tomorrow I promise.
Haha, the arm press.
Someone call a vet, cause these pythons are SICKKK
Jeezus is offline   Reply With Quote
Old 09-23-2009, 08:40 AM   #62
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Originally Posted by Jeezus View Post
Did you get Tim's old exhaust?
Yeah he acquired my old setup. Good to see it live on in another 7.
Old 09-24-2009, 07:32 AM   #63
BigIslandSevens
BigIslandSevens's Avatar
Here is where it stands as of last night. I "may' Start it up today. I have a few things to complete on the battery relocation and it will be ready to power up again.
the rear wheel wells undercoated
The rear axle housing assembly and watts linkage, new poly bushings installed
Forgot a good shot of the wrapped headers. Later tonight I guess.
Old 09-24-2009, 10:08 AM   #64
Jeezus
I love new and new looking parts
Keep it up dave! Let me know on how the relocation went. Did you pick up a kit from summit?
Old 09-24-2009, 11:27 AM   #65
t_g_farrell
Waffles - hmmm good
Front looks great, now get the rest of it painted That color rocks, I like it.
Old 09-24-2009, 01:47 PM   #66
BigIslandSevens
I have a Aluminum battery box from Jegs that I don't use. If you didn't want to mount it in the bins
I grab all the stuff I need for the battery from the local NAPA/Advanced. A quick list off the top of my head is as follows:
10' 2 gauge battery cable( for the main POS and NEG cables)
10' of 8 gauge battery cable.( for powering up the fuse block)
2-4 8 gauge ring terminals
2-4 2 gauge ring terminals
2 Battery post terminals
1 rubber grommet for the hole I am drilling thru the body for the cable
I fabricate my own battery hold down once I figure out exactly where it is going.
5-10 cable "hlod down " clamps to secure the cable to the underside of the car or wherever you run it
1 main fuse( about 100A) that is installed at the battery POS in case the power wire should short to the chassis it will disconnect the battery. In theory I get theses from the car stereo store.
It may be less hassle to just grab a kit, but I am probably around the 30-50 dollar range in parts depending on the quality of cable you use. Plus I have done a few of them so I have a good idea of what I will run into.
Yeah Tim, The rest of the car is super fugly compared to the enginebay! I am working on it!!
Old 09-26-2009, 05:04 PM   #67
BigIslandSevens
Update:
I have the rear axle and diff installed into the car. Replaced the rear axle bearings as well. I just got done laying down the color and clear onto the front and rear calipers, and resprayed the hood latch.( uneven coverage)
Due to the non-stop rain I cannot get back out and finish the wiring and fill the diff. Add oil , and start the car. Maybe tomorrow as it is supposed to be sunny.
Old 09-27-2009, 09:06 PM   #68
BigIslandSevens
Wiring is done, calipers are painted and installed. Watts installed. Small progress today. Filling all cases with oil tomorrow. And firing it up...hopefully
Old 10-01-2009, 08:39 AM   #69
BigIslandSevens
It's alive!! Started rite up after filling the bowls with fuel and a good backfire that echoed thru the hood at 7:30 AM Runs nice and smooth. Which means I did not screw up any wiring when I "simplified".
Bleeding the brakes today and possibly test driving with the new gearing and bushings.,
Old 10-01-2009, 12:04 PM   #70
Congrats man - thats awesome!
Old 10-01-2009, 08:44 PM   #71
NoDOHC
NoDOHC's Avatar
Wow! under 2 months, maybe I need to figure out where you buy your water....
I can barely get a set of engine rotors polished in 2 months
Old 10-02-2009, 08:17 AM   #72
BigIslandSevens
I get my water from the local crack springs!
2 months has only gotten me finished with the enginebay and all parts included. And the rear axle conversion. I still have the door jambs, doors, rear hatch jamb, underside of the hood and the entire exterior to paint. So probably another month at least.
it is inspiring to hear it run again though.
Old 10-02-2009, 10:35 AM   #73
t_g_farrell
Waffles - hmmm good
So you still think you'll be making it to the OGTA meet for October?
If you do the November one I'll come down with you.
Sounds like your really making progress. I'm in the middle of stripping the undercoat off my gas tank before I redo it. What a mess! Lots of small rust spots too! Hopefully none of them go thru.
Old 10-02-2009, 04:38 PM   #74
Jeezus
Dave inspires us all
It is looking real good there! I am still super jealous you got the 4.77! Gotta tell me what that is like. I am looking for one to, would love to wipe the smile off my brother's face when my FB beats his power hardtop miata!
Any new pictures of the engine bay?
Old 10-02-2009, 04:47 PM   #75
BigIslandSevens
Nothing new done to the enginebay. I did spray the air cleaner base black today. The clear is just dry enough to touch. It will get mounted tomorrow. I need to get a can of gas as iI didn't think the gauge was working.....It is Ran out when I tried to move the car back up the driveway for a test.
Also the rear brake distribution block on the axle is leaking. As well I think the Master cylinder may be bad. It has a wierd feel about halfway thru the stroke. ( Kinda expected this as it is off a junker car of who knows how long) I may just grab a reman from the zone tomorrow.
Glad I can help inspire keeping the 7 alive!
You planning on going to the blue ridge cruise/meet Stu?
