| Carburetors and Carb Tuning.. All info about old school carb set ups.. |
|  01-26-2010, 07:26 PM | #1 |
| tumor-syphilis-itis-osis Join Date: Sep 2008
				Rep Power: 18  |
				boosted fb any advice?
			I have an 82 gsl, with a built 12a, running quite a large turbo with a custom four injector throttle body and mega squirt blah blah blah, I hate it- mega squirt totally blows and I would love to go carbed, everyone says rotary shack but I have yet to be able to get ahold of anyone there-  anyone on here know where I can get a good carb to run a reliable 220-250hp like I was getting before my mega crapped out again? I like old tec, the less electronics the better
				__________________ 82 300d 82 Gsl 84 b2200 Diesel 88 gxl |
|  01-26-2010, 09:32 PM | #2 | |
| Custom User Title Join Date: Feb 2008 Location: Seattle, WA / Pullman, WA
				Rep Power: 18  |
			Holley double-pumpers and Weber DCOEs are good candidates for blow-through. There's very little involved in boost-prepping a DCOE; as I understand it, use a neoprene float bowl gasket and teflon-tape anything threaded (save the idle mixture screws, obviously), and you're good to go. I hear Weber IDAs can be done without much trouble, either, but I don't know any specifics as to what's required. The original site is down, but there's a writeup on boost-prepping a Holley here: http://web.archive.org/web/200805050.../blowthru.html Other than that, it's just a matter of building a carb hat and tuning it.
				__________________ Quote:
|  01-27-2010, 08:12 PM | #3 | |
| Rotary Fanatic Join Date: Mar 2008 Location: chatsworth, california
				Rep Power: 18  | Quote:
  and of course installing a locked distributor bor boost.
				__________________    rotaryshack.com | |
|  01-27-2010, 08:59 PM | #4 |
| Respecognize! Join Date: Jul 2008 Location: Δx = ħ/2Δp
				Rep Power: 21  |
			what happened to the megasquirt
				__________________ For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook |
|  01-28-2010, 07:48 AM | #5 |
| Rotary Fanatic Join Date: Sep 2008
				Rep Power: 18  |
			There is no problem with the Megasquirt, the problem is in one of the injectors; the car ran perfectly when I handed it off to him. The megasquirt was in some doubt, since both injector drivers went out on the one I originally sold him (however, it worked that morning before I pulled the engine and etc from the car), so I chalk that up to a wiring mistake. I re-wired the engine, made a new megasquirt for him, and re-tuned the new ecu at no labor cost, and it ran -perfect- for the week or so it was around the shop before he came and picked it up. But, running the Megasquirt on the simulator, everything checks out. |
|  01-28-2010, 08:23 PM | #6 |
				Rep Power: 18  |
			^^^basicaly the engine doesn't want to run unless ryan's behind the wheel, but I thought the original problems all spawned from the mega squirt issue?
