Old 10-23-2010, 03:12 PM   #1
Crankcase vapor vent/recirc system
Most of us seem to just "T" the oil filler nipple and the center iron nipple together and run it off to a puke can. Some leave Jem open, some cap them but what would be the best way to clean out the vapors, keep the oil moisture free and not add any check valves, pwm or ecu activated valves? Something very very simple.
What I'm thinking of doing would involve a 2 chamber "tank." Both vertical. The first chamber would have a filter on the top, a drain on the bottom and would be connected to the center iron nipple.
The 2nd tank would have no filter on the top, be plumbed to the oil filler neck from the bottom, packed with SS wool, and the top would be plumbed to one of the TID's.
The thought is the small amount of vac created would constantly circulate air through the crankcase. And oil that traveled up the center iron would first be pulled back in before getting to the puke tank where it could be drained. Any vapors or moisture that made their way up the filler neck (very unlikely that oil would as I have basically a funnel in there to keep that from happening) would be caught by the SS wool before getting pulled into the intake.
Thoughts, comments, suggestions are all welcome especially from Ted. I know he has a great deal of knowledge with this.
Old 10-23-2010, 06:01 PM   #2
I think you've over complicated the matter, but that's just me.
Old 10-23-2010, 06:17 PM   #3
Right now I've got both nipples "T'eed" to a puke tank. The oil gets milky and fuel saturated pretty quick. Not to mention I'm constantly draining the fucker at the track, just about every run I'm draining it. I'm actually lucky I've missed all the track days this year, the thing would've overflowed from oil creeping up the center iron. Last auto-x I actually left the drain open
Old 10-23-2010, 07:31 PM   #4
when you get here we can figure it out. i may be able to help ya with it. It just seems too complicated to me as I am able to have no issues with only a filter... but that could be for other reasons too...
Old 10-24-2010, 04:51 AM   #5
I'm assuming this is for an FC.
Is this purely a "crankcase" evac system?
Since I didn't read anything about the gas tank vapor purge, I'll assume this is not part of your system...
I like the idea of running the crankcase with some vacuum.
Having the crankcase pressurized could possibly hurt power and / or cause headaches like smoking turbos.
The hard part is...how do you do it?
The stock system is overly complicated.
Mazda's stupid "purge valve" is another one of those engineering-bragging doohickeys that makes things a headache.
When we run race cars on the track, we 1) cap the bottom nipple on the center iron, and 2) run a single vent off the top of the oil filler neck.
Whether you want to run it as a recovery system or a purely purge / vent system is up to you.
Oil *will* creep up the oil filler neck to easily spew out the lower fitting in the center iron when you toss the car around the track.
Even with oil baffle pans, you can still get oil puking out that lower fitting.
We've never had too much problems with oil puking out the top of the oil filler neck.
I'm also assuming that this is for a turbo 13B.
This is good and bad.
Running vacuum in the crankcase relieves pressure that would end up puking oil out the piston compressor ring in the turbo turbine.
Effect?
Oil spews out the hot turbine section and burns in the exhaust causing embarassing oil smoke.
Bad?
Push the turbo hard enough and this causes the oil to foam more after the CHRA.
Foaming, hot oil causes more vapor crap, which causes more crap to get puked out the system.
Another bad thing...
With a turbo engine, the only "spot" that has constant vacuum is before the turbo.
If we're talking purely vapor, this would not be a problem.
In reality, we're also ingesting (hopefully) minute amounts of liquid that's hitting a (delicately) spinning compressor wheel.
Mazda decided to do this full-time with their system.
It's probably the best, passive system that could be integrated into engine at that time.
Old 10-24-2010, 08:23 AM   #6
Yup, on an FC with a 13B-RE. There is nothing for the fuel tank. I built my own cell with an in tank surge tank and have the cell vented to atmosphere. Works well, no smell.
I've got both nipples t'eed together and run to the puke tank. Yeah, it does creep up badly. But, if you cap the iron nipple, run the oil filler to a vac source, does that ceate enough flow through the crankcase to clean things out? I would imagine that you would want a constant flow of air in one port, out another. With that center iron nipple capped, the only source to relieve the vac is the blowby or the oil entering the pan. I would imagine that it would be a little more effective to leave the iron nipple open, but filter the air going into it, no?
[QUOTE=RETed;131045]I'm also assuming that this is for a turbo 13B.
Effect?
Bad?
Foaming, hot oil causes more vapor crap, which causes more crap to get puked out the system.[QUOTE=RETed;131045]
Yes, you are correct, twin turbo 13B. The twins are notorious for not liking pressure and puking/burning oil easily. Even the rebuilds. Both my CHRA's are damp with oil, but she'll only burn and puff smoke if sitting for a LONG time or if overboosted slightyl. Kinda why I want to get a bunch of vac in the pan and was THINGKING about overcomplicating the whole thing with a vac tank..... but then slapped myself out of that idea.
This is exactely why I wanted to run the vac source through the filtered puke tank before it heads to the turbo. Was also thinking about running a clear fuel filter inline as well just as a last ditch effort to catch anything that migh do damage hitting a comp wheel spinning way too fast. Like you said, purely vapor would not be a problem, but some sort of debris or the sludge that often collects, would be a huge problem hitting those comp wheels under full song.
So, would you change anything on the setup that I have in mind?
Thanks Ted, I appreciate it
Old 10-24-2010, 10:06 AM   #7
Interesting point...
We were just worried to keep the pressure out of the crankcase.
The point was just to relieve the pressure.
I wouldn't think circulation would matter.
Ah, now I see why your design is so complicated.
It's sorta like running a "charcoal canister" system for the crankcase evac...
Yes, what you are proposing does make a lot of sense.
It looks like you've got all the bases covered - condensation of vapor / moisture, drainage, and purge to combustion.
The clear lines are a plus - this is why some (Japan) racers like to use those clear lines: to inspect the crankcase puke.
I've got mine current T'd, and you're right - there's a LOT of puke that comes out of those lines.
I had my hose pop off my pipe prior to the turbo inlet, and there was a LOT of disgusting coffee / mud colored liquid that came out of there.
I'm too lazy to redo right now, and the stock turbo puked it's seal a while ago.
When I change the turbo out, I think I'll redo the system too.
I like your plan of attack on this matter, and it should work.
I think it's just a matter of having enough volume in your catch can system...
We also know how tight space becomes in the FC engine bay with big turbo systems and FMIC's!
Old 10-24-2010, 05:54 PM   #8
I've heard that some sort of constant circulation is needed to keep some moisture out and to get rid of the blow-by gases... prolonging the life of the oil.
Cool, thanks... I'll add this on the list of shit to do before the road trip. Give it a real test in short time.
I couldn't believe it either. At one point I was draining about a pt every other run out of the thing. Drove me insane. Then after not checking it for a few days I pop my hood to see oil all over the back of the divider right behind the drivers side headlight and on the front of the drivers shock tower.... I'm thinking oil lines popped somewhere but instead it was the puke tank overflowing (mounted on the drivers shock tower) and the BO valve spraying it all over the engine bay. :faceplam:
I'm thinking about a pt off the center iron and ~2/3's of a pint off the oil filler. I took a SS turkey baster and cut it down, used the gasket between the oil filler and the center iron as a template, cut that out of SS and welded it together, a funnel to keep the oil from moving up the filler. This is why the capacity in for the filler will be less. There should be little to no oil traveling up that. I'm also hoping that what does creep up the center iron will be pulled back slightly as I want to have the vac being pulled from there, through the filler neck, through the SS wool packed ~2/3's pt tank, through some hose, through a clear filter, to the primary turbo. We'll see what happens. I guess I should try to log the vac seen by the TID. I've got that secondary boost MAP sensor that I only hook up on the dyno.... that could do it. If there's no vac present, or very little... I may have to think about a small vac tank somewhere....... Hoping it doesn't come to that though. That would REALLY overly complicate things....
Thanks Ted. i'll get some pics up in the fab section when I start creating.
Old 10-25-2010, 02:36 PM   #9
coolmike711
coolmike711 is on a distinguished road
What I did was run a vacuum line from the oil filler to vacuum source on the behind the TB.
The crankcase nipple I T'd with one to the charcoal can and the other to a catch can with one way check valve. No PCV.
I kept blowing turbos with the factory stock PCV system. Once I put a consant vacuum source on the filler neck, no more problems.
I don't do track like you guys, but lets just say that i do spirited street driving.
coolmike711 is offline   Reply With Quote
Old 10-25-2010, 05:48 PM   #10
Did you put a check valve on the line from the oil filler to the source behind the TB? On a turbo car this source behind the TB would see pressure as well as vac.
Old 10-25-2010, 07:46 PM   #11
coolmike711
There is a check valve that plugs into the original stock TID, it's in the FSM. I used that just before the line gets to the catch can.
There are 3 nipples on the UIM just behind the TB that face the front of the car. This is where the original vacuum lines from the PCV went. So I just used that for vacuum, ran the line to the oil filler neck.
I got so pissed of with the stock setting causing too much pressure build up in the oil pan. So once I had constant vacuum on the oil pan I could redline now with no fear.
Old 10-25-2010, 08:11 PM   #12
AH, TID is different from TB...
Old 10-26-2010, 12:08 AM   #13
coolmike711
If you look at this vacuum diagram you see what I mean. Of course all the other vacuum lines are gone.
So I get rid of the PCV and run that one line from the fill neck to one nipple on the UIM with vacuum. Plug the others.
Then from the crankcase it's set up just like the diagram with one line going to the canister and the other with the check valve on the end going to the catch can. I know I can do without the check valve but i kept it.
Old 10-26-2010, 09:33 PM   #14
joff
joff is on a distinguished road
Here's what I'm having welded into my downpipe for crankcase evacuation--
It supposedly draws a decent vacuum as long as there is exhaust gas flowing and you weld it in at a 45deg angle to exhaust flow. I hope it works -- I will find out soon enough.
Personally, I like the idea of sending crankcase vapors down my exhaust than through the turbo and motor.
joff is offline   Reply With Quote
Old 10-27-2010, 08:27 PM   #15
I like! Where did that come from?
