Old 11-12-2010, 05:46 AM   #18
As far as the rotors... my feelings, it's obviously damaged, gases are going to get in there and do things that it shouldn't do. The pressures can force the apex seal/corner seal harder into the sealing surfaces than they should and cause accelerated wear... I know someone who tried this by milling gas ports into the rotors. Killed the housings in about 5k from what I understand.
That little imperfection could lead to the seal moving back and forth and wear improperly. Also thinking carbon buildup is going to increase in that area as well.
This is basically the primary reason to worry about clearances.
This is why I mentioned as long as the clearances should be measured.
Pics can sometimes distort dimensions, so it's always prudent to go measure everything yourself.
Side note...
There will always be a little blow-by past the seals.
Anyone who has opened up a high mileage motor (with stock OMP still intact) and checked the rotor apex seal grooves has seen the crap that gets lodged under there.
For the most part, IMO, that carbon build-up is relatively soft.
The apex seal is bouncing up and down in the groove and will most likely just mash all that carbon build-up under it until no more can fit under it.
From my experience, just swapping out the stock OMP with pre-mix greatly reduces the amount of carbon build-up in the engine.
Also, having the fuel mixtures tuned right (not excessively rich) will greatly minimize this carbon build-up also.
At the same time, it's a given that your ignition system be working in top shape to fire off the combustion charge, as misfires are just as bad as a too much fuel.
