Show your rotary car build up. Show off your Rotary Car build! |
サバンナFC3S RX-7
My サバンナFC3S
Well my FC has been my first car, and like every RX7 owner you have a love hate relationship with your car. I blew my engine during spring break of my freshman year of college.
After much patience I finally sent my engine to Lucky7Racing in El Monte California to get rebuilt. Here are a couple of pictures of my series 5 N/A engine as it gets turbo sleeves installed and a medium street ported. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Series 5 GTU Last edited by Gabriel82; 02-05-2011 at 09:23 PM. |
サバンナFC3S RX-7
Since we have to wait for a couple of parts to come in for the actual rebuild. Fris at Lucky7 painted the engine and mocked it up
Series 5 GTU |
サバンナFC3S RX-7
A couple of pictures of my brakes before my engine took a dump.
I upgraded from the 1 pot GTU calipers to the 4 piston calipers from a series 5 vert model. Had them rebuilt, same with the rear. Also came up on an actual GTUs LSD unit for really cheap. (The LSD unit is on the right) ![]() ![]() ![]() ![]() ![]()
Series 5 GTU |
サバンナFC3S RX-7
More progress done on the engine =]
Series 5 GTU |
サバンナFC3S RX-7
So my dad has been rebuilding brake boosters and brake master cylinders for a very long time. He finally taught me how to do it. Here is a picture of the new rebuilt booster. I also changed out the clutch master cylinder while I was at it.
Series 5 GTU |
At the dirt track.
Lookin good.
Rollin like a reuleaux. Unstoppable. |
I have radioactive semen
the ports look good. i also like what you did with the brakes. how involved is it to rebuild a brake booster?
good job overall. |
サバンナFC3S RX-7
Hmmmm well my dad has a lot of inventory so he had the replacements for the diaphragms inside. Basically you open up the booster take out the diaphragms, change them out, check out the seals, re-grease the seals and the hub. Paint the shells. It's a little tricky, but luckily my dad has decades of experience so he guided me through the process.
As for the port job thanks, Fris at Lucky7Racing is doing a great job.
Series 5 GTU |
#9 |
サバンナFC3S RX-7
So the engine should be arriving this week. I'll post some more pictures of it once I get a chance. I'll also put some before and after pictures of the transmission after I gave it a good cleaning. + a couple of before and after pictures of the power steering after it had it rebuilt. Too bad I won't be able to install the engine until I finish up this term =/ at least I'll get to install my engine with the whole RB Street Exhaust system after I get more money.
Series 5 GTU |
#10 |
Down with OPP
Very nice job. Have to ask, what do the japanese letters in your title mean?
86 base, TII swapped, Rtek 2.1, some other things. Daily driven. |
#11 |
サバンナFC3S RX-7
サバンナ means Savanna
so essentially my thread says: My Savanna FC3S RX7 I just converted Savanna from english to Japanese using a translator.
Series 5 GTU Last edited by Gabriel82; 01-31-2011 at 12:05 AM. |
#12 |
Down with OPP
Ah makes sense.
#13 |
サバンナFC3S RX-7
Engine is almost done just needs the intake manifold, block off plates, etc.
![]() Pineapple Racing Intake Inserts ![]()
Series 5 GTU |
#14 |
nice build i should be like this in a few weeks! btw how much did your rebuild cost you?
#15 |
サバンナFC3S RX-7
Thanks dude, good luck with your build.
Series 5 GTU |
Bookmarks |
Thread Tools | |
Display Modes | |
