Old 04-01-2011, 02:02 PM   #1
Ignition wiring sanity check
I'm getting ever closer to installing my stand alone (in fact I'm planning on wiring the power side of things tomorrow and crimping the cannon receptacle): I'm installing the quicksilver coils and want to wire them up on a plug prior to full installation. The trouble is they have no documentation that is sent with them. As such here's what I do have:
I have 5 wires coming off from the ECU that will be connecting to these. 4 switched grounds (one for each coil) and a 12v switched source (don't worry it's relay'd).
My thinking is this:
A - 12V+ switched
B - Switched ground wire
C - Chassis Ground
D - Chassis Ground (or should I really run a wire to the battery ground?)
E - 12V+ Battery
Is this wrong, or is there a better way to wire this up? Thanks.
