Old 04-04-2011, 06:46 PM   #34
Judge Ito
Porting Master
Judge Ito is on a distinguished road
12A bridgeport
I just did a 12A bridgeport for a daily driven Mazda B2200 pickup. using Goopy's refinished rotor housings with apex seals. I wanted to do a compression test as close to real numbers as possible. I did not lube the side housings with oil and I did not lube the rotor housings with oil. basically a dry build and dry test. I did not want the lube oil to add to compression numbers. engine made 125psi equally on both front and rear rotor. enjoy the pics..
Judge Ito is offline   Reply With Quote
