#16 |
crash auto?fix auto
Start starter hunting
![]() BTW, I want to steal your dog. EDIT: Just noticed J-rat's terminal jumping suggestion. Forgot about that, give it a shot. Last edited by classicauto; 04-07-2008 at 01:09 PM. |
#17 | |
Big Daddy
I actually have no idea how to. Let me go hunt for a writeup. EDIT: Could it be a bad switch on the clutch? How can I check that?
Hell hath no fury like a rotor blown. Last edited by $100T2; 04-07-2008 at 01:15 PM. |
#18 | |
Thats what I suggested too....I have had that wire vibrate off several times before.
#19 |
Big Daddy
Here's some more pics.
Unless you guys see something seriously amiss, I'm going to go ahead and order a new starter.
Hell hath no fury like a rotor blown. |
#20 |
Rep Power: 20 ![]() |
Things look a bit rusty under there. Maybe you're just not getting a good connection.
#21 |
crash auto?fix auto
*Looks* alright............I'd pull that main positive off the large post and sand up both sides of the contact before removing it though just in case.
Also, might wanna go ahead and bolt that little black resistor box back down though. Theres a few in the engine bay, ones for your oil pressure guage. |
#22 |
Big Daddy
I'll try taking the whole starter off and cleaning everything up, then bolt it back on.
What little black resistor box???
#23 |
crash auto?fix auto
This little baby:
It just needs to be grounded somewhere. I believe this one was under the slave cylinder originally. Last edited by classicauto; 08-07-2008 at 12:01 PM. |
#24 |
I just replaced my old, worn out starter wit a new one, and that peice /\ fit on a metal tab on both starters. Was it loose like that the WHOLE time?
#25 |
Big Daddy
I don't know if it was loose like that or not... Today was the first time I've been under the car.
#26 |
My friends prelude did that btw. His starter clicked, but didnt move. I gave it a tap, then the ger spun, but it was still too weak to move the engine over. We overnighted a new one, dropped it in, and the car fired up right away. Dunno how broke you are, but $90 for a reman starter is a good investment, I think.
#27 |
Big Daddy
Not broke at all, just having issues with all three vehicles at the moment. It's more of an issue of "which do I deal with first" than money.
#28 |
First of all, that black box thingy is a damping capacitor for the oil pressure gauge.
It's not going to affect anything that has to do with the starter. Just connect that to ANY ground. For a Turbo II, it's bolted down by one of the bolts on the clutch slave cylinder. WHAT SCARES ME THE MOST IS THE FACT THAT THE MAIN ENGINE GROUND IS NOT CONNECTED!!! Look BEHIND the black box in that pic - see the big ring terminal? That's the main engine ground connection that is usually secured by the long starter bolt! This NEEDS to be securely connected, of your engine isn't properly grounded. The starter grounds through the engine block - no engine ground; starter doesn't work well - hell, a LOT of stuff won't work well. We're talking the main ECU grounds are on the engine, as are how the spark plugs fire through the engine block too. Some of the pics confuse me... In another pic, it looks like the water temp connector (yellow wire with female bullet connector) is routed all that way to the starter... How did you manage that? -Ted |
#29 |
Big Daddy
I didn't do any of it... This is how the car came to me. I will try to get the car all the way up in the air today to give you guys some really good pics, so we can figure out what goes where.
#30 |
crash auto?fix auto
Good idea.
Ted - didn't even see it. Its a tough point of view to distinguish things ![]() |
Bookmarks |
Thread Tools | |
Display Modes | |
