I'm not sure abotu the notch but if you are looking through the inspection cover on the exhaust side of the engine... when you line up the flat section of the flywheel parallel to the exhaust flange then the engine is at TDC. Your marks should be close to the pin. Should easily be able to determine bolt holes by then.
someone correct me if I am wrong.
