Old 12-01-2011, 04:14 PM   #1
Originally Posted by C. Ludwig View Post
On these NA engines, with the quality and results of the ID injectors, I see no reason to run secondary injectors. Personally, I would run a single 1000cc injector per rotor. This eliminates the tuning headache of secondary injectors. The ID-1000s will idle great, so why not?
+1 on the ID injectors. I'm running 4x ID1000 in a stock configuration with a SprintRE and and my idle has never been better. Much better than the previous 20+ yr old (cleaned and flow tested) stock 550cc injectors.
Very simple and uncluttered solution.
Old 12-01-2011, 04:39 PM   #2
Pettersen
Next question:
wich flywheel and clutch will give me some streetability but be good on track to? Engine specs further up in the thread.
Also i am using a NA transmission now, but i have a T2 trans i want to use. What is needed in order to install it except from a T2 driveshaft? Do i need to do anything with the rear diff?
Old 12-01-2011, 05:10 PM   #3
My5ABaby
My5ABaby's Avatar
+2 I'm running 2x1000 to replace cleaned/flowtested stock 460s on my N/A and my idle is better than it was for the prior 7 years of owning the car and I've only spent about 20 minutes tuning the idle. I got mine from Full Function Engineering.
Community Service Manual
RotorWiki
