Old 01-05-2012, 06:03 PM   #1
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Right.
Thats why I have the "Junk" trans, its an FB trans. Going to use the tail section.
The problem is my FB drive-shaft doesn't bolt up to the Diff, not even close.
Old 01-05-2012, 08:30 PM   #2
jfaplanet
jfaplanet is on a distinguished road
Driveshaft
You probably need a 83-85 driveshaft. The earlier ones had a smaller mounting point to bolt to the rear diff. An easy way to tell is to look at your FB driveshaft, if the u joints are removable, then its an early one. Hope this helps your cause.
jfaplanet is offline   Reply With Quote
Old 01-06-2012, 09:17 AM   #3
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Don't cut up those drive shafts just get the right one like jfaplanet says. That
would be the cheapest solution as well. Sell the others for profit!
I can't wait to see this one back with a rotary in it. Maybe Tray will take note.
