Old 01-18-2012, 08:37 AM   #26
JustJeff
JustJeff's Avatar
Thanks! Those are the only pictures I took before installing it back in the center console, so the additional side views may have to wait. These are the basic Prosport "Performance series", oil pressure, water & oil temp gauges that don't have the peak/hold warning features. If your gauges are significantly deeper, the bracket sides behind the panel will limit how much you can angle them. The good thing is that it doesn't take much of an angle to make them readable - presuming you don't sit too close to the wheel.
Sounds like your water temp gauge may have a fried stepper movement since you tested both the wiring & sender by substituting in the oil temp gauge. I'd check w/Prosport to see if they will cover it. The OP gauge sounds like either a wiring issue or a bad sender.
My temp gauges must be older version. They are much deeper than yours. My Premium/warning Prosport pressure gauge is short like yours. I doubt that Prosport will cover them because I bought them all from forum members. The temp gauges were used and the pressure gauge was new but not purchased from a vendor.
Originally Posted by yzf-r1
